My 2001 Silverado [ 55,000 miles ] has a goofy fuel gauge. While sitting at a traffic light the gauge will read empty and the " low fuel ' light will come on. Then when I rock the truck while sitting in my seat the gauge will become accurate again. I've read where this is a problem in sub-freezing weather, but this is almost May and it's in the 80's here. What is this I read about sulfur in the fuel possibly being the cause. Will a can of Sea Foam solve that problem?
Share this post
Link to post
I had a similar problem on my wife’s Yukon. I ended up having to replace the fuel pump to fix the problem with gauge. You could put some fuel system cleaner in the tank hoping that in cleans the contacts. In my case it did not help.
Share this post
Link to post
Get a couple of bottles of Chevron's Techron, part # 65740 and run it at 1 oz per gallon. You may want to try it for 2 tanks. It contains an additive that will help remove deposits from the sending unit. It will not repair a faulty sending unit but if it is not ready properly due to deposits, it will cure the problem.
Worse case, you will have spent $20.00 but you will have the cleanest fuel injectors, intake valves and combution chambers in town. :lol: Techron is one of the few Fuel System Cleaners that truly does what it claims.
Share this post
Link to post
If you mean part # 67740 [ last 5 digits of bar-code ], Wal-Mart has the 12 oz. bottles for about $6.00 each. It says on the bottle that it helps to get rid of sulfur-causing problems pertaining to the fuel gauge sending unit. I bought 2 bottles to use at my next fill-up.
Share this post
Link to post
Is this Techron Fuel Cleaner Concentrate stuff safe for the engine? I've been running it in my current tank at 1 oz per gallon and my truck hasn't been wanting to start up. It starts up the first time I turn the key, but it struggles and really has to work to start. Is that normal?
Share this post
Link to post
65740 is a 20 oz bottle. $6.00 on a 12 oz bottle is a good price.
Truemoron, The Techron should not have any negative affect whatsover on your truck. I have been using it for years and we sell a good bit of it with no issues at all.
Share this post
Link to post
