P0101 Error Code Help
#1
Posted 26 May 2008 - 04:28 PM
I have a 2002 2500HD with the 8.1L motor. I ran an engine diagnostic and received error code P0101.
Where should I start troubleshooting this error code?
Thanks
#2
Posted 28 May 2008 - 04:18 PM
#3
Posted 28 May 2008 - 04:22 PM
#4
Posted 06 June 2008 - 07:17 PM
#5
Posted 21 June 2008 - 05:02 PM
P0101 CODE =MASS OR VOLUME AIR FLOW CIRCUIT RANGE/PERFORMANCE THE FIRST THING ID BE TRYIN WOULD BE CLEANING MASS AIR FLOW SENSOR ESPECIALLY IF YOU USE AN OILED FILTER SUCH AS k&N sorry bout caps to lazy to retype lol
I have a K&N air filter. Can you please direct me to the location of the mass air flow sensor?
Thanks.
#6
Posted 06 August 2008 - 12:59 PM
When you shut the engine off, the MAF goes thru a "burn-off" cycle where it heats up the filament wire to remove any dirt or build up on it.
This is definitely how it works on my '88 Trans Am and from what I understand, current MAF sensors still work the same way.
#7
Posted 06 August 2008 - 06:50 PM
Thanks.
The MAf is directly after the airbox inline to the intake. There is a wire harness attached to it so you can't miss it. I had the same problem with my K&N on my '01 6.0L. I cleaned the the sensor with contact cleaner and the code cleared itself.
2005 BMW 645Ci convertible w/only 19k miles
2013 Ford C-Max SEL Hybrid (hers)
Please PM me if you have any questions or concerns.
#8
Posted 06 August 2008 - 08:43 PM
Got the K&N with FIPK and got the code while towing 10,000lbs in 90 degree temps.
It reset itself without any cleaning.
I read somewhere else where a GM tech explained that is was the airflow increase beyond set parameters of the MAF and not the oil from the filter that was the cause.
I would like to know the real cause since most think it is the filter oil. Of course, K&N denies there is any problem on their website calling it a myth.
#9
Posted 06 August 2008 - 09:27 PM
The K&N filter oil shouldn't be passing through the element and building up on the MAF sensor. Not if it's oiled properly. I've used a K&N Series 77 CAI for a while with no trouble till I drove thru a very dusty area one day. Set off the P0101 code. Cleaned the filter and the code cleared.
I'm now running an AEM Dryflow (oil-free) filter and after a few months I'm now getting a P0101 code. Cleaned the filter a week or so ago and the code went away, but today the MIL came back on.
There's just something about CAI kits and the factory MAF.
#10
Posted 10 August 2008 - 06:15 PM
Pulled the air filter and took a look at the MAF screen. Tiny piece of debris was on it so I wiped it off with my finger. This left a a lcean streak of silver. A closer look showed that there was some soot on the surface of the screen.
I wiped it off with a soft cloth and also used a can of compressed air and blew it through the screen. Put the filter back on and fored up the truck. The MIL went out within seconds and has not come back on.
#11
Posted 14 August 2008 - 09:36 AM
I still intermittently get the P01 error code. What else could it be if cleaning the MAF did not resolve the issue?
#12
Posted 02 December 2008 - 11:50 AM
I've been dealing with this issue for awhile. Not sure if I need to replace the K&N filter or replacing the MAF.
Any other advice would be appreciated.
Thanks.
#13
Posted 06 December 2008 - 09:53 PM
Could the PO101 error code also be related to the oxygen sensor?
Thanks.
#14
Posted 31 December 2008 - 09:52 PM
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
