Add Second Battery?
#1
Posted 29 July 2008 - 12:51 PM
This works great but makes me nervous that a cold night (and lots of furnace operation) will drain the battery and the truck wont start the next morning. So, I have been considering adding a battery to the popup to operate the lights and furnace.
I noticed that the Suburban has a spot for a second battery under the hood. Has anybody added a battery in this location to serve their camper? I thought it might be good to do it this way so that the battery will charge when I drive around during hte day.
1. Is this a good idea?
2. Should I run the batteries together all the time? (ie the second battery is there all the time)
3. Should I make it so that the second battery is soley for the trailer? (ie take it out after camping done for the year?)
Does anybody have any ideas or thoughts for me?
Thanks!
#2
Posted 29 July 2008 - 12:57 PM
Don
#3
Posted 29 July 2008 - 01:23 PM
2007 GMC Sierra Z71 SLT Crew Cab 4x4 6.0L 4l70e 3.73 gears 5000k HID low beam and driving light upgrade.
Modifications: True Flow PAI, HPTuned (Removed HUGE PE Delay, Added 30 to speed limiter, modified AFM/DOD for better MPG)
#4
Posted 29 July 2008 - 01:31 PM
I would add a deep-cycle battery to the camper. It is set up for this.
Don
this is option 2 if adding it to the truck isnt the way to go. the camper is not really set up for it, I need to add a tray to the tounge and some wiring to hook it up. My concern about this method (and the reason to look into adding it to the truck) is that after multiple nights of camping the battery will be worn down and I wont have any way to charge it. i was hoping that adding it to the truck would allow it to charge while I drove during the day.
is it possilbe to add a deep cell battery under the hood, connect it only to run the trailer, and still be able to charge it while driving? I am thinking no, but dont know...
#5
Posted 29 July 2008 - 01:45 PM
#6
Posted 29 July 2008 - 02:00 PM
2006 Silverado, Victory Red, Z-71, 5.3L HO, 295/70-17's, 2" AAL,
3" Lift Keys, Vette Servo, Magnaflow cat back, 6000k HID's
And a few other things.....
Member of the RED TRUCK CLUB
ACS Customs
#7
Posted 29 July 2008 - 08:45 PM
#8
Posted 03 January 2009 - 07:04 PM
If someone can verify that the parts are the same for a 2007 Sierra as they are for your Burb' then I can give you the part numbers and some other information that had been given to me by MS3Dale and M. Cueva. I am looking to do pretty much the same thing and setting it up as if it was from the factory with the dual battery setup.
Sorry to bump an old thread, but I'd love to get the P/Ns for doing this on my '08 Sierra. I want to be able to install an Optima deep-cycle (yellow top) aux battery so I can use my power inverter while the truck is off and not have to worry about it starting afterward.
Stealth Gray Metallic | Ebony UltraSoft Leather | 5.3L FlexFuel AFM-Delete V8 | 3.73 Locking Differential (G80)
Airaid MIT | K&N Drop-In | HP Tuners | Line-X Over-the-Rail | Fold-a-Cover G4 Elite | Spencer's 6K HID Conversion Low Beams and Fogs | OEM Navigation | OEM OnStar Bluetooth | Addco Front & Rear Sway Bars
2009 GMC Envoy Denali 4WD
Quicksilver Metallic | Ebony Leather | 5.3L AFM V8 | 3.42 Locking Differential (G80)
"IEATSRT8'S" CAI | Hotchkis Rear Sway Bar | HP Tuners
#9
Posted 06 January 2009 - 01:25 AM
Sent you a PMIf someone can verify that the parts are the same for a 2007 Sierra as they are for your Burb' then I can give you the part numbers and some other information that had been given to me by MS3Dale and M. Cueva. I am looking to do pretty much the same thing and setting it up as if it was from the factory with the dual battery setup.
#10
Posted 10 November 2009 - 09:57 AM
I have a 2009 Sierra 1500 SLT, Crewcab and want the second battery for same reasons, ACCESSORY power while engine is off.
Yes, local dealer will install (just like factory) and warranty for 12 mo. 12,000 mile but they want $800. to do it!!!
Any one has .pdf plans or schematic for a do-it yourself?
I promise NOT to DUCTtape wire over roof or hood!
Thanks,
rib54
rib54{no-spam-please}@excite.com
#11
Posted 11 November 2009 - 09:05 AM
Have 6 of them in my golf cart !
WeatherTech floor mats / GM moulded mud flaps
#12
Posted 03 March 2010 - 10:13 AM
Could I also get those P/Ns for my 08 GMC Sierra? Thanks.
#13
Posted 03 March 2010 - 10:59 AM
Take a look at this thread:
http://www.gm-trucks...showtopic=56398
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
