MountaineerTom Posted August 18, 2008 Share Posted August 18, 2008 My power steering went out Friday. I was driving in a field and turned the wheel to the left and got on the gas a little bit to sling the rear around. Did it a second time a few miutes later and noticed that the steering got very stiff. I got out and checked under the hood, no leaks, fluid level was good, but no power steering. At low speeds, it's very hard to turn the wheel in either direction. At first I thought the power steering pump went out, but after I searched around a little I found some talk of a pressure swith that goes bad. Could this be my problem? There is no whining or anything. Actually, nothing is different, other that very hard to turn the wheel at low speeds and stiff while at faster speeds. Link to comment Share on other sites More sharing options...
DofD Posted August 18, 2008 Share Posted August 18, 2008 I had the power steering go out in my '90 Silverado with the symptoms as you describe (the stiffness). For me it was the pump that died. From what I can find, it may also be the power steering pressure switch. Replacing the pressure switch would be an easier and cheaper test to see if that is the problem. Link to comment Share on other sites More sharing options...
cntrlfrk Posted August 18, 2008 Share Posted August 18, 2008 I had something very similar happen once on my '97 Silverado. No squealing, No leaks, nothing. When I went to change the pump, I removed the belt and put the pulley puller on and the pulley fell off in my hands. The shaft had sheared in half just inside the housing. I was lucky the entire pulley didn't fly off while I was driving! Link to comment Share on other sites More sharing options...
MountaineerTom Posted September 1, 2008 Author Share Posted September 1, 2008 Is the pressure switch the part that is in the pump, after you take the hose off? I've heard heard something else about disconnecting a connector under the dash, on the steering column. Anyone know anything about that? Thanks. Link to comment Share on other sites More sharing options...
minibike132 Posted September 1, 2008 Share Posted September 1, 2008 I'd say first thing, take off the belt and pull on the pulley. I'm almost positve you sheered off the shaft, if you pull on it and it moves at all it's junk. Link to comment Share on other sites More sharing options...
MountaineerTom Posted September 1, 2008 Author Share Posted September 1, 2008 I'll check that first. If it is sheared, that's a pump replacement, correct? Link to comment Share on other sites More sharing options...
MountaineerTom Posted September 1, 2008 Author Share Posted September 1, 2008 Thanks sparkstech, you nailed it. Link to comment Share on other sites More sharing options...
minibike132 Posted September 1, 2008 Share Posted September 1, 2008 Yep you need a new pump. Make sure you get the special tools to remove the pulley and install it on the new pump. Do not try to hammer or press on the pulley, you'll push the shaft on the new pump and sheer the vanes off again. The special tool to install screws into the shaft and then pulls the pulley on to the shaft. Make sure you get it all the way down so that your belt is alligned when your done or you will get noise and go through belts. Link to comment Share on other sites More sharing options...
MountaineerTom Posted September 17, 2008 Author Share Posted September 17, 2008 I finally got around to changing the pump out the other day. Not too difficult, just some tight spots to try and get to. All is good now. Thanks for the info and advice. Link to comment Share on other sites More sharing options...
minibike132 Posted September 17, 2008 Share Posted September 17, 2008 Glad you got it fixed . Link to comment Share on other sites More sharing options...
-[Rupes]- Posted October 3, 2008 Share Posted October 3, 2008 i am going to be changing my pump this weekend on my 02 4.3l sierra... is there a step by step kicking around? Link to comment Share on other sites More sharing options...
mooman Posted January 23, 2009 Share Posted January 23, 2009 bump. Looking for the "How to"? Link to comment Share on other sites More sharing options...
Norseman Posted January 23, 2009 Share Posted January 23, 2009 bump.Looking for the "How to"? To Remove: Remove or disconnect the following: Upper radiator fan shroud, if necessary Battery junction block from pump bracket, if necessary Drive belt Pulley Nut and clamp retaining the filler neck to the power steering pump, if equipped Place a drain pan under the pump Remove or disconnect the following Hoses from the pump Bolts from the rear of the pump Bolts from the front of the pump Pump from the vehicle To Install: Install or connect the following: Power steering pump Bolts to the front and the rear of the pump and tighten the bolts; Torque to: 37 ft. lbs. (50 Nm) Hoses to the pump and tighten the nut; Torque to: 20 ft. lbs. (28 Nm) Nut and clamp retaining the filler neck to the power steering pump, if equipped Install the pulley with 0.5 mm (0.020 in) play Drive belt Battery junction block from pump bracket Upper radiator shroud Fill and bleed the power steering system Test drive the vehicle to confirm the repairs Link to comment Share on other sites More sharing options...
