armboy9589 Posted September 5, 2008 Share Posted September 5, 2008 I have a 2004 2500 HD with the codes: C0201 ABS Enable Relay Contact Circuit C0035 LF Wheel Speed sensor C0040 RF Wheel Speed Sensor I have cleaned the ground for the EBCM and that did not solve the problem wondering if anyone has had this happen or know of a way to solve it or what the resistance should be in a wheel sensor. I just have a hard time believing that both sensors would go out at the same time or if it is a common problem. Thanks A lot Chad Link to comment Share on other sites More sharing options...
minibike132 Posted September 5, 2008 Share Posted September 5, 2008 Hey Chad, welcome to the site. Wheel speed sensors should be about 700-10,000 ohms. I hate to guess at things but there isn't much guidance I can give on paper on this set of codes, so all I can say is that usually if you have the C201 in this vehicle and fixing the ground doesn't help then the Electronic Brake Control Module is the fault. I hate to have you guess and have that not be it because it is expensive. Good luck to ya. Link to comment Share on other sites More sharing options...
armboy9589 Posted September 5, 2008 Author Share Posted September 5, 2008 Hey Chad, welcome to the site. Wheel speed sensors should be about 700-10,000 ohms. I hate to guess at things but there isn't much guidance I can give on paper on this set of codes, so all I can say is that usually if you have the C201 in this vehicle and fixing the ground doesn't help then the Electronic Brake Control Module is the fault. I hate to have you guess and have that not be it because it is expensive. Good luck to ya. Are these modules a common problem i just dont know much about GM vehicles and their common problems. Link to comment Share on other sites More sharing options...
minibike132 Posted September 6, 2008 Share Posted September 6, 2008 No they are not very common. I would have someone check it out before guessing at this part. Link to comment Share on other sites More sharing options...
