Can A Factory Trailer Brake Controller Be Added?
  • Please log in to reply
8 replies to this topic
#1 snowpromod
snowpromod
  • Member
  • 8 posts
Posted 26 October 2008 - 09:28 PM
Hi,
We just picked up a 2008 GMC Sierra 1500 and would like to know if a factory brake controller can be added? The dealer says "no", is this 100% accurate! The site is great and I have learned a lot from looking around! Thanks
#2 MS3DALE
MS3DALE
    Don't call me,and I won't call you!
  • Senior Moderator
  • 14,831 posts
  • Name:Rich
  • Gender:Male
  • Drives:'07 Silverado Z71 '11 Camaro SS '02 Saturn SC2
Posted 26 October 2008 - 09:48 PM
He is correct,It cannot be added.
We've discussed this many times....There are too many parts that are either different,or that need changed out.
The brake master cylinder,booster & chassis wiring harness are just a few of the parts that are different.
You would also need to add the switch,brake controller module,relay & dash trim piece to just name a few of the new parts needed.
Your truck also must have Stabilitrak,You also would need to get the BCM reprogrammed,And thats if the dealer would be willing to try and reprogram it,most won't due to liability issues.
Posted Image
'07 SILVERADO Z71 LT2 "VortecMAX" 6-Liter,"Super-Duty" Auto Trans,9 1/2" rear-end w/3.73 G80 Locker,XM,On-Star,BOSE speaker system,Stabilitrak,Block Heater,Sunroof,18" ARE "Cannon" Wheels w/LT275/65R18 Goodyear Wrangler AT/S tires.
Custom tune by Justin at Black Bear,CORSA "Sport" exhaust system,EXTANG "Full-Tilt" snapless tonneau cover,Rough Country 1.5" front leveling kit,Fabtech 1" rear lift blocks,EZ-Down tailgate damper.
GM accessories...Hood Deflector,Molded Mud-Flaps,Ventvisors,Catch-All Floor-Mats,Bedrail Protectors,BedRug Bedliner & Bedmat,and a GM Performance Parts cold-air intake.
2011 CAMARO 2SS/RS - LS3/M6 - Inferno Orange Met. - HURST short-throw - Roto-Fab CAI - Kook's LTs - CORSA exhaust - Black Bear tuned (playtoy!)
2002 SATURN SC2 - 3-Door Coupe - Orange Met. - auto-sunroof-leather (work car!)
My Garage
#3 Outbacker
Outbacker
  • Member
  • 625 posts
Posted 26 October 2008 - 10:00 PM
Rather then going with the factory controller, I would recommend the Tekonsha Prodigy brake controller. Probably cheaper then the factory one, but more reliable. I have not used a factory one, but I have never had an ounce of trouble with the Prodigy.
Bob
Victoria, BC
Canada
2008 GMC Sierra SLE Extended Cab, 5.3 L Iron block, 3.73 rear ratio, Katzkin leather interior, Putco vent visors, Westin step bars, Prodigy brake controller
Posted Image
#4 irengineer
irengineer
  • Member
  • 77 posts
PI regarding adding ITBC
Attached File  Adding_ITBC.pdf   70.76K   301 downloads
2007 Sierra 2500 HD K25743 Black
2009 Yukon XL 2500 HD K25906 Black
2009 Silverado 2500 HD K25943 Red
2009 Sierra 2500 HD K25743 Gray
2010 Sierra 2500 HD K25743 Black
2010 Yukon XL 2500 HD K25906 Black
2011 Sierra 2500 HD K25743 Black
#5 snowpromod
snowpromod
  • Member
  • 8 posts
Posted 26 October 2008 - 10:16 PM
Thanks - it looks like an aftermarket unit!!!
#6 elcamino
elcamino
  • Member
  • 1,120 posts
  • Gender:Male
  • Drives:2012 GMC Sierra Denali, 2009 Cadillac CTS4
Posted 27 October 2008 - 08:53 AM
I am going to have one installed on my 2008 also. I was told to make sure its a "Proportional" type as those are the best. Such as the Tekonsha P3 and they have direct plug in wire harness's for new GM trucks according to advertising.
Edited by elcamino, 27 October 2008 - 08:56 AM.
Mike
#7 Gixxer188
Gixxer188
  • Member
  • 25 posts
  • Gender:Male
Posted 17 December 2008 - 10:33 PM
Odd, I had the techs at the dealer I work for look this up the other day on gmdealerworld and they say just the opposite of what you all have been saying.
They say that you can't install an aftermarket control and that you have to install the GM ITBC.
2008 GMC Sierra 1500 X-Cab 4X4 SLE Black
#8 slammeddually
slammeddually
  • Member
  • 62 posts
  • Gender:Male
Posted 26 January 2010 - 04:20 PM
I installed one in my 2007 New body Silverado.
Here is a how to video that i found and used. It works great!
http://www.etrailer.....MC_Sierra.aspx
#9 alaskaLTZ
alaskaLTZ
    Now What??
  • Member
  • -7,666 posts
  • Name:Scott
  • Gender:Male
  • Drives:2009 2500HD CC 4wd LTZ
Posted 27 January 2010 - 01:33 AM
Yeah they were wrong. As stated above, we all went through this on my previous '07, and it isnt possible. I went with the P3, the wiring is right there below the dash. Works great.
Posted Image
2009 Silverado LTZ 2500HD Crew Cab 4x4 6.0 6L90
(not quite stock)
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
Advertise Here
