gnet158
How Do I Wire A Line Out Converter?
I want to add the mono amp and '10 infinity sub from my old truck into my new truck. I want to keep the factory H/U so I need to install a LOC. I've searched this forum and found that a few members recommend the PAC Trunck-LOC because it has the remote on feature.
I have a few questions.
1, What exactly do I need to connect the 3-4 wires to on this unit? I've installed an Alpine/amp/sub on my old truck so comfortable with wiring.
2. Where do I pass the amps power cable through? Is the rubber grommet in the same spot as in the older trucks? This is what I used before.
3. How do I remove the trim around the radio to get to the harness?
4. What gauge wire do you recommend? 6 or 8?
Thanks!
Share this post
Link to post
here are the answers to your questions:
1: to connect the loc (line output converter) you need to remove the dash and remove the headunit. splice into the the rear speakers left and right
LR Speaker +/- brown= + yellow= -
RR Speaker +/- dk. blue= + lt. blue= -
2: You can run the power wire from the front and send it through in the rubber that conceals the wires on the passenger side door. (ribbed rubber sock thing) ive done that for my 2007 silverado and my friends 2008 silverado
3: To remove the plastic trim around the radio you start from the top right near the passenger seat and just pull that out and just work your way around.
4: 8 gauge wire is fine + less powerful amps dont have big enough inputs for bigger wire
Hope this helps
Share this post
Link to post
Hope this helps
Than answered all my question!
Thank you, Thank you, Thank you!
:lol:
Share this post
Link to post
What is the total rating of the fuses in the amp?
Through the door jamb? Not a great idea.
Share this post
Link to post
The amp has two 20 what amp fuses, it's a 100W mono amp.
Why do you think it's a bad idea running the amp's power cable thru the doors? Do you have a better way for me to run it to the battery?
Share this post
Link to post
Just making sure. You can use 8 gauge wire like jzizzo said, but you might want to consider thicker wiring if you think you might upgrade later on.
Good way for the wire to get pinched. Drill a hole in the firewall and use a rubber grommet if you have to.
BTW, you don't have Bose do you?
Share this post
Link to post
Nope, just the stock radio.
Thanks for the info, I'll keep that in mind.
Share this post
Link to post
it definitely isnt going to get pinched. this guy is wrong. i have 4 gauge wireing going through that way and for my friend i ran 1/0 wiring the same way. guess what.. no pinching
if you need to see it i can take pictures
Share this post
Link to post
That would be great!
Share this post
Link to post
You don't need to use a bigger wire...your amp is only a 100 watts you could use speaker wire to power that
8 gauge is fine
thats what i use to power my 1000w mono block amp
and like jzizzo the small amps don't have big enough terminals for a bigger gauge
i ran my power cable from the bat across the top of the fire wall and then through the firewall where there are already holes drilled on the driver side
Share this post
Link to post
8 gauge is fine
Are you serious, speaker wire?? I didn't say he had to use anything thicker than 8 gauge, I just mentioned that it might be a good idea to run thicker wire now in case he would ever get a bigger amp.
Share this post
Link to post
thunderstuck does have a point about running the bigger gauge now if your amp can use it now. and ill upload pics tomorrow when i get done with school
Share this post
Link to post
lol yeah ive done it
sry i didn;t mean to put you down
but an 8 guage is plenty even for a bigger amp
im running a 1000watt mono block d class
no prob
Share this post
Link to post
