Camshaft Eating Distributor Gear
  • Please log in to reply
12 replies to this topic
#1 kyphantom
kyphantom
  • Newbie
  • 4 posts
  • Gender:Male
Posted 15 January 2009 - 09:25 PM
I have a 1993 G.M.C. Yukon with a 5.7/ 350, i have just rebuilt the motor and made some upgrades, the upgrades that i have made are i bored the block .030 instaled a set of L98 heads a GM factory LT1 roller cam and a GM factory distributor gear that was susposed to work with the camshaft, the engine has less than 10,000 miles on it since the rebuild, i had to pull the distridutor to fix an oil leak and found that the distributor gear had been eaten by the camshaft. can anyone give me any ideas on how to stop this from happening again? none of the aftermarket companys make a bronze distributor gear for a small shaft GM Distributor. Thanks For Any Info
#2 chrisbmo2000
chrisbmo2000
  • Member
  • 87 posts
Posted 16 January 2009 - 07:58 AM
eaten how??? got any pics???? sounds like the gear was not the right one after all but pics will tell the story
Chris
Chris
1997 Chevrolet Suburban LT 2WD
5.7 L
4L60E Trans
207000 miles and counting
Power EVERYTHING
Descreened MAF
#3 66nova
66nova
    Black Bear Tuned
  • Member
  • 2,350 posts
  • Gender:Male
Posted 16 January 2009 - 09:04 AM
Did you go back with the factory intake? I have had aftermarket intakes that I had to shim or machine to make the distributor fit right. Sounds like the teeth are not meshing correctly. Even if you didn't change intakes you changed heads, fit could be a little different.
Because I don't know if the bronze gear is going to fix the problem by itself.
I would check distributor depth first, then if every thing looks good, I would look for an aftermarket distributor with a bronze gear.
Good luck, and lets see pics of that ride.
Finally a Garage Entry
Posted Image
rickordsanimalhospital.com
2007 Crew Cab Vmax GMT900 with a Blackbear Tune (Kool-Aid Video) (Corsa Touring Idle)(Corsa Touring AFM)
(Corsa Touring Passing)
1995 GMC 2/4 drop, Edelbrock Headers, Flowmaster Cat Back, Hypertech Chip, Jacobs Ignition, K&N
1966 Nova 408 SBC 10.80s on the motor...9.89 @ 135 on a 150 shot Exhaust Note Took Darkanion for a Ride With 150 NX Kit in and out of throttle
#4 txab
txab
    Your worst fWONking nightmare
  • Moderator
  • 6,901 posts
  • Gender:Male
  • Drives:2004 GMC Sierra
Posted 16 January 2009 - 10:26 AM
+1
Posted Image
"When the people find they can vote themselves money, that will herald the end of the republic."
-- Benjamin Franklin
Posted ImagePosted ImagePosted Image
#5 pennzoil29
pennzoil29
    The life I live, the cards I play, the hand that I just dealt
  • Member
  • 5,893 posts
  • Gender:Male
Posted 16 January 2009 - 10:33 AM
What they said. :lol:
Posted Image
#6 kyphantom
kyphantom
  • Newbie
  • 4 posts
  • Gender:Male
Posted 16 January 2009 - 11:01 PM
Still has the factory intake and distirbutor, distirbutor height is factory. the best way i can describe the the wear is the teeth on the distirbutor gear are tring to knife edge. tried to take pic of the gear but did not turn out well.
#7 66nova
66nova
    Black Bear Tuned
  • Member
  • 2,350 posts
  • Gender:Male
Posted 16 January 2009 - 11:03 PM
Have you checked the cam gear to see if it messed up too?
Posted Image
#8 kyphantom
kyphantom
  • Newbie
  • 4 posts
  • Gender:Male
Posted 16 January 2009 - 11:16 PM
Not yet, GM said the the cam was a billet with a cast iron distributor drive gear so the factory distributor gear would work, this cam is the one that comes stock in a 1996 Z-28 LT-1 Camaro,
#9 66nova
66nova
    Black Bear Tuned
  • Member
  • 2,350 posts
  • Gender:Male
Posted 16 January 2009 - 11:42 PM
If I were you, I would start a post HERE
There is not a better engine site.
Posted Image
#10 wheelsthatgrip
wheelsthatgrip
  • Member
  • 43 posts
  • Name:Keith
  • Gender:Male
  • Drives:2008 Silverado LT 4x4
Posted 17 January 2009 - 09:01 AM
Could the oil pump input shaft be too long? This would cause the distributor to sit higher and also cause an oil leak as you have described. It would also lessen the gear tooth contact and subsequent wear. :lol:
Regards,
Keith
#11 Jo Nathan
Jo Nathan
  • Member
  • 24 posts
  • Gender:Male
Posted 17 January 2009 - 05:36 PM
You probably need a cam button. I had the same problem with my '91 when I rebuilt it about 6 years ago. I converted it to a roller cam and the cam would "walk" forward on deceleration and grind on the distributor gear until it was razor sharp. Look into a cam button.
Posted Image
#12 66nova
66nova
    Black Bear Tuned
  • Member
  • 2,350 posts
  • Gender:Male
Posted 17 January 2009 - 05:40 PM
Good thought.
Posted Image
#13 kyphantom
kyphantom
  • Newbie
  • 4 posts
  • Gender:Male
Posted 17 January 2009 - 06:27 PM
The wear is from top to bottom on the teeth on the gear, and the block that i built was set up from the factory for a roller cam with a cam plate behind the timing gear and i went back with every thing from chevy. the cam, the cam retaining plate ,the roller lifters, and the lifter retaining plate. the oil leak was caused by a bad gasket.
Edited by kyphantom, 17 January 2009 - 06:30 PM.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Advertise Here
