- 0
Gm Tbi No Injector Pulse While Cranking
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 29 Members, 2 Anonymous, 1,636 Guests (See full list)
Question
camaro_thunder92
I am helping out a co-worker on this one. He swapped a 91 TBI 350 into an 85 chevy truck. The engine will run if you either spray starting fluid down the throttle body or hook up a remote start switch. If you use the key, there is no injector pulse while cranking. As you let go of the key and return it to the run position, the injectors give one squirt. Here is the checklist:
Painless wiring harness
Fuel pressure: good
Fuel pump primes when key is turned to run position
Plenty of spark under crank position
12v to injectors at run and crank position
No pulse while in crank
Like I said, the truck will start and run if we use a remote starter switch and injectors pulse. It will also start and run with the key if we use starter fluid or gasoline through the throttle body.
Thanks in advance for any help you are able to provide.
0 answers to this question
