- 0
1999 Suburban 4x4 With A 5.7...starts But Then Dies Right Out
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 28 Members, 0 Anonymous, 1,965 Guests (See full list)
Question
ShortyYFZ450R
This has happend on 3 different occasions, out of nowhere it just won't start and then if I wait a couple days it will start up & run fine for a couple weeks or a month & then do it again. This time it hasn't started though...I've checked the compression, it's 150. I checked the spark, it's firing. I checked the fuel pressure, it goes up to 61 & then drops right down to 56 & holds there steady. It will start but then dies right out. If you spray carb cleaner in the throttle body, it will stay running but it's pretty rough. I put a new fuel pump & fuel fliter on it 14 months ago and I put all new cap, rotor button, spark plugs & wires on it 3 months ago. It had a code back then that said cylinders 2 & 8 were misfiring but when I tuned it up that fixed that problem. I had a friend come over and the only code showing up now is the oxygen sensor, he cleared the codes and now it won't run long enough for any codes to show up.
Thanks! Any help will be appreciated!
0 answers to this question
