MB4x4
2000 Jimmy V6 Running Rich...?! Need Advice.
Well I just bought a 2000 GMC Jimmy 4.3L V6 and it throws two OBD codes:
P0172 Bank 1 running rich
P0175 Bank 2 running rich
I googled for it, it could be some clogged injectors but the idle is perfect and there is no lack of power. I went to the GM dealership they told me it could be the MAF but finding out the real problem could cost some $$$ and a MAF alone is 284$.
Anyone else had the problem? I put some Injector cleaner in the tank but it did nothing except that the light doesnt stay on all the time but goes off from time to time.
I believe the light comes on once the engine is hot.
Any advice would be appreciated. Thanks!
Share this post
Link to post
Clean the MAF and see if that solves the problem. The only other problem I can think of is the FPR or the spider is bad.
Did you not check the vehicle over before you bought it?
Share this post
Link to post
Well I looked at the maf, it looks clean, the sensors aren't dirty neither is that screen. I cleaned the air filter. It was not dirty, too.
I knew about the codes when I bought the car, I got it cheaper therefore.
Share this post
Link to post
