2005 Silverado Tachometer And Speedometer Problems.
This topic has been archived. This means that you cannot reply to this topic.
10 replies to this topic
#1 BAKO_BOB
BAKO_BOB
  • Newbie
  • 2 posts
Posted 01 July 2009 - 01:51 PM
The speedometer and tachometer are showing erradic values while driving. The speedometer will reach the appropriate speed, then fall off and go back to zero. The tachometer will get stuck at weird RPM's, then a short while later will correct itself. What is wrong?
#2 bill190
bill190
  • Member
  • 728 posts
  • Gender:Male
Posted 01 July 2009 - 03:03 PM
If these problems both started happening at the same time, then I would think it would be an instrument cluster problem.
The signals for both of those head off to different directions and things, so the only thing in common is the instrument cluster electronic module. (And power / ground to that module.)
But as with all electronic problems, it is a good idea to check your battery voltage (should be 12 something volts with just ignition on/ 13/14 volts after starting), check that the battery terminals are clean and tight. Check main electrical wires from battery to be sure the connections are clean and tight. This includes a negative large cable from the battery to the body ground and to the engine block.
Also you can try removing the instrument cluster, then unplug the electrical connector, then plug it back in and be sure it is snug.
#3 BAKO_BOB
BAKO_BOB
  • Newbie
  • 2 posts
Posted 20 July 2009 - 10:33 AM
The speedometer broke first, then about six weeks later the tachometer started sticking. I'm pretty sure that the problem with the speedometer is the drive line speed sensor. The tachometer i'm not so sure about; but I think that it is most likely the instrument panel.
#4 04Z71Blackout
04Z71Blackout
  • Member
  • 61 posts
  • Gender:Male
Posted 20 July 2009 - 08:52 PM
the problem you more than likely have is the stepper motor inside the instrument cluster itself and eventually all six gauges will quit working there are services offered on ebay (not advertising them just saying) that will replace them and all bulbs in the cluster for something like $150 i just did this myself everything is soldered in and screwed my circuit board up now am having to buy a whole new cluster most people seem to have good luck replacing them themselves but i didn't but like i said more than likely the stepper motor
#5 bossier62guy
bossier62guy
    Senior Enthusiast
  • Member
  • 1,669 posts
  • Name:John
  • Gender:Male
  • Drives:2002 Silverado Z-71
Posted 20 July 2009 - 09:19 PM
GM might replace it depending upon the mileage you have on your truck....I think the magic number is 70K but I'm sure someone will correct me if I'm wrong.
#6 Gary WW
Gary WW
  • Member
  • 10 posts
  • Gender:Male
Posted 21 July 2009 - 12:55 PM
I believe that is correct. We found out about it when they were still having it delayed in court. By the time it was done we were past that lovely number and you needed to have it documented by a dealership in order to have it fixed at their cost. Of course we didn't know that until they were done. Dealerships charge you $700+ to fix it.
#7 tom14
tom14
  • Newbie
  • 3 posts
Posted 22 July 2009 - 11:14 AM
I have an '04 silverado with v6 and automatic. My cluster's speedo and tach quit working at 85k, well past the warranty repair. I've seen the ads for repair services and have thought of just replacing the cluster. I found a site online that states a new cluster with extra for programming the mileage, etc. other than that, it is supposedly 'plug and play'. I've also found a few for sale thru ebay. What model years would work; ie, 2003-2005, or 2003-2007? And could I get one for a v8 and not a v6 as the v8's seem to be more available? Would it really be 'plug and play' with a used one, or would it still have to be programmed to not set any cel's?
Thanks
#8 KYoutback
KYoutback
  • Member
  • 265 posts
  • Gender:Male
Posted 22 July 2009 - 01:20 PM
I just recently replaced the stepper motor for my speedometer after fighting with the dealer over the fact that I was 5,000 miles over the extended warranty. They "were willing to work with me" and pay half. My "half" was $400. I bought a stepper motor off ebay for $10 and it took me about an hour. It's really pretty easy.
Posted Image
#9 chevyp2p
chevyp2p
  • Newbie
  • 1 posts
Posted 23 July 2009 - 11:47 AM
I also had a speedometer problem in my 2004 Chevrolet Silverado
the speedometer was not working at all and I found a website where I had it fixed for $140. That was a lot cheaper than the $700 that the dealer wanted to replace the instrument panel.
Here is the website
in case you want to check it out: http://www.speedometergaugerepair.com
#10 Fred Allen Burge
Fred Allen Burge
  • Member
  • 4 posts
Posted 13 August 2010 - 10:11 AM
Hey BAKO,
I had the same kind of problem with my 2003 Z71, I repair these now for people as a service, I'm not the cheapest bargain basement guy but I do have the best warranty and I cover shipping, both ways. My site is drspeedometer.com, thanks.
#11 Chris
Chris
    Senior Enthusiast
  • Community Manager
  • 15,747 posts
  • Name:Chris Hawkins
  • Gender:Male
  • Drives:2004 GMC Sierra SLO6OH
Posted 14 August 2010 - 07:48 AM
i had it. gm will replace it if u have less than 7 yrs 70,000. i have an 04 sierra. speedo went erratic. i was driving based off rpms. i finally took it to my gmc dealer i had 78000 on it. they replaced it anyways for free.
2004 GMC SIERRA 1500 EXTENDED CAB SHORT BED, DARK SPIRAL GRAY METALLIC, LQ9 6.0 LITER V-8, TUNED BY BLACK BEAR PERFORMANCE, FLUIDYNE THERM-HX TRANS COOLER, VOLANT INTAKE, CORSA SPORT, 05+ E-FANS, DC POWER 300 AMP ALTERNATOR
BUILD: http://www.gm-trucks...un-daily-build/
