Dually Conversion
This topic has been archived. This means that you cannot reply to this topic.
7 replies to this topic
#1 JWRambo
JWRambo
  • Newbie
  • 3 posts
Posted 01 July 2009 - 11:51 PM
Has anyone done a dually conversion on a 2500 HD? I have a '05' 2500 HD Duramax, and need to increase the towing capacity. Anybody know how much the conversion would increase towing capacity? Are there any other differences between the 2500 and 3500? All I could see is the addition of a helper spring. I have already purchase some Super Springs, and they eliminate squatting when towing heavy loads. They also do not seem to affect the unloaded ride. Any help would be greatly appreciated.
#2 HDdady
HDdady
  • Member
  • 32 posts
  • Gender:Male
Posted 05 July 2009 - 03:44 PM
I believe the extra tires are more for stability than payload
#3 brims
brims
    Senior Enthusiast
  • Member
  • 1,605 posts
  • Gender:Male
Posted 05 July 2009 - 05:14 PM
Legally you can't raise the capacity.
Posted Image
2008 Chevrolet Silverado 1500 Extended Cab Standard Box, 2LT, 4x2, 5.3L FlexFuel, 3.73 G80, Graystone Metallic, General Grabber HTS 245/70R17
Mods: Line-X over the rail, WeatherGuard Crossbox, Optima Red Top, MagHytec Differential Cover, Rough Country 2" leveling kit, Corvette Servo, AEM Brute Force Intake, Black Bear tune, Hayden 679 aux trans cooler, Hawk pads, Bilstein shocks, Dual Aeroforce Interceptors, Extang Snapless Full Tilt Tool Box Tonneau
Future mods: 2 low/6 high
Possible mods: rear sway bar, blacked out front and rear bumpers
#4 5-0stank
5-0stank
  • Member
  • 209 posts
Posted 05 July 2009 - 06:21 PM
Unless you get the dually parts for dirt cheap, I would probably just trade the truck for a dually.
2009 2500HD 4x4 6.0 :: Leveled, GMC 17"s, 295/70R17 Nitto Terra Grapplers
1994 Mustang GT :: 5.3/4L80E swap project
#5 DBVille
DBVille
  • Member
  • 170 posts
  • Gender:Male
Posted 05 July 2009 - 10:26 PM
I don't know, but I suspect there are a slew of differences - springs, spring mounting points, axle, etc. Its not as simple as adding dual rear wheels to increase the towing capacity.
As others have said, by a heavier truck - it will be cheaper than building one yourself.
DBVille
2005 Suburban 2500
Birmingham, AL
#6 RideoutKSC
RideoutKSC
  • Member
  • 53 posts
Posted 12 September 2009 - 10:39 PM
They make/made single rear wheel 1-ton trucks. How much are you towing exactly?
Posted Image
2004 Silverado
5.3 4x4 long bed regular cab
Cowl induction hood
20" rims
#7 99chevy7.4L
99chevy7.4L
  • Member
  • 421 posts
  • Gender:Male
Posted 14 September 2009 - 02:52 PM
The axle weight is the critical number there. A single rear wheel is rated for 6200 on the rear axle give or take the dually is rated for around 7500 give or take on axle weight. The GVW may be about the same yes but the axle weight is what will give a lil more capacity. Alot would depend on whether factory bed is on the truck or if the vehicle has a work body, flatbed etc. The stock chevrolet beds are heavy. My white dually has a flat bed on it made of 3 inch channel and metal diamond plate it is some 200 pounds lighter then the factory bed. Just a lil INFO.
7.4L vortec, Airaid Cold Air Intake, EFI-Live, LS1 injectors, Derale Cooling tube pan, Bilstein shocks, Magnaflow 2.5inch Dual IN/OUT
Posted Image
#8 sstimothy
sstimothy
  • Member
  • 842 posts
  • Gender:Male
Posted 17 September 2009 - 09:27 AM
The duramax carries the 1 ton axle. 11.5 inch full floater. Your axle capacity is fine. The only difference between a 3500 and a 2500 HD (duramax or 8100) is the extra rear springs. If your not hauling water or livestock the dully is a moot point. Just add the helper springs and you have a 1 ton, axle and all.
2015' GMC Crew Cab, SLT, Dmax/Allison, 4X4
Onyx Black w/Cocoa Dune
G80, skid plate package, driver alert package, DVD/BluRay, camper mirrors, 5th wheel wiring, winter covers, too many option to name on one page, etc...etc...
