The 2022 GMC HUMMER EV will be a big launch for General Motors. Both figuratively and physically. GM-Trucks.com has learned the company’s very first all-electric truck will tip the scales at 9,046 lbs.
If that sounds like a lot of weight, you’re right. It’s a simply crazy curb weight for a pickup truck, let alone a “light duty” pickup. For reference, a 2022 GMC Sierra 3500HD with a crew cab, dual rear wheels, and the LP5 Duramax Diesel only tips the scales at 8355lbs. Yes, you read that right. The HUMMER EV will weigh more than a heavy-duty dually pickup.
We can only assume this is because the truck’s Ultium Battery system is heavy. Super heavy. In fact, we kind of got an idea this would be the case when the Cadillac LYRIQ was announced a few weeks ago. The LYRIQ will weigh over 5,600lbs with half as many Ultium Battery Modules as the HUMMER EV will carry.
GM-Trucks.com also has a more detailed list of GMC HUMMER EV Edition 1 specs. That includes cargo volume and gross vehicle weight. Check it out below.
GMC Spokesperson Mikhael Farah added to our report: “The GMC HUMMER EV – the world’s first all-electric super truck – has unmatched super capabilities, all in a zero emissions package. With specs like 1,000 horsepower, 11,500 lb.-ft. of torque and a blistering 0-60mph time of 3-seconds, the GMC HUMMER EV Pickup is bound to shatter expectations of what an electric vehicle can do.”
More news on the GMC HUMMER EV is coming soon from GM-Trucks.com
2022 GMC HUMMER EV Detailed Specifications
Specifications | |
Front suspension travel, in. (mm) | 13.00 (330) |
Rear suspension travel, in. (mm) | 13.00 (330) |
Adjustable ride height, (max), in. (mm) | 7.82 (199) |
Turning diameter, curb-to-curb, (2-wheel steer), ft. (m) | 44.3 (13.5) |
Turning diameter, curb-to-curb, (4-wheel steer), ft. (m) | 37.1 (11.3) |
Approach angle, Standard (degrees) | 41.5 |
Approach angle, Terrain mode (degrees) | 44.3 |
Approach angle, Extract mode (degrees) | 49.7 |
Departure angle, Standard (degrees) | 31.6 |
Departure angle, Terrain mode (degrees) | 33.7 |
Departure angle, Extract mode (degrees) | 38.4 |
Breakover angle, Standard (degrees) | 22.3 |
Breakover angle, Terrain mode (degrees) | 25.4 |
Breakover angle, Extract mode (degrees) | 32.2 |
Capacities | |
Curb weight, lbs. (kg) | 9046 (4103) |
Cargo volume, cargo bed, cu. ft. (liters) | 36.7 (1039.3) |
Cargo volume, front trunk (frunk), cu. ft. (liters) | 9.0 (254.9) |
Gross Vehicle Weight Rating (GVWR), lbs. (kg) | 10400 (4717) |
Seating capacity | 5 |
