Showing results for tags 'lowering kit frame modified'.
Picked up a used 17 Sierra, and found out it used to have a lowering kit installed, and then put back to stock height. Alright, no problem. However, upon further inspection, they had removed the bump stops by cutting off the entire drop down bracket that was welded to the frame. One of my questions is with that bracket now gone, I am unable to install the Firestone 2430 load helper air bag kit as it mounts to the part where the rubber bumpstop would normally sit. What are my other options. Truck will remain at the factory ride height for now. I know you can get air helper bags for lowered vehicles, but they might not work on this truck as they would be running close to max operating extension length sometimes. Ideas anyone?
