Showing results for tags 'remote oil filter'.
New Member hoping to shake some fruit from the tree of knowledge: I have 2015 Silverado Z71 with the 5.3L L83 engine. I installed a remote oil filter relocation kit from Hamburger Performance to relocate the oil filter from the awful factory location to the nice empty space in the engine bay, right behind the driver's side headlights. I already have an external transmission filter kit in this same spot. (3rd pic is of new oil filter on the left with blue tape on inlet line, transmission filer kit is just to the right of oil filter kit) . I got tired of oil puking on me when changing the filter and wanted to run a larger oil filter than stock. My question is: has anyone else done this Mod. and if so how did they route their oil lines from the old filter location up into the engine bay compartment? From the stock filter location (2nd pic) , there is a tiny space inside the front left frame rail and I've got my oil lines snaking between the front drive shaft and the driver's side exhaust manifold (Pic # 4 & 5 oil line is black braided nylon hose). I'm getting a loud whining noise which I'm pretty sure is the oil lines pulsating against the frame or exhaust heat shield. I'm considering re-routing the lines to the outside of the left frame rail and bringing them up inside the drivers side wheel well (1st pic) but this seems less than ideal as the lines would be somewhat exposed to road elements or suspension movement. The good news is I've got good oil pressure (40 lbs at idle, 60-80 lbs @ 3750 RPM once the second stage oil pump kicks in) so I know I hooked them up correctly and oil is flowing. I've changed oil filters thinking that might quiet the noise but no luck. Any advice would be greatly appreciated.
