- 0
Gas Won't Stay In Carb Why ?
Recently Browsing 0 members
246k
Total Topics2.6m
Who's Online 13 Members, 0 Anonymous, 1,970 Guests (See full list)
Question
BAD2500HD
I have a 1979 GMC K25 it has the 350 and is a auto the problem i am having is the gas won't stay in the carb , if it sits for just a day or two it will start up but much past that and you have to pull off the cleaner and spray in some gas to get it going cranking it and pumping the gas does nothing we have looked it over and can't seem to find a leak and it doesn't seem to be getting into the oil that i can tell or into the motor its just like it never had gas in it , it does have the duel tanks and i did put on a new fuel pump . once you get the truck running it seems to run great it has around 66,000 miles on it any clue as to what i need to do ? when person said the carb needs a rebuild another said i should put a check vavle in the line but i thought there was one in the pump ? also after sitting like i said for a few days the pump is dry too , any help would be great as i need this truck for the winter etc. ! Thanks
0 answers to this question
