  • 0
Tsb For 2007 Yukon Xl Denali- Power Running Boards
Retrofitter
Question
I am having intermittent problems with my power running boards not coming out and very intermittent, not going back in. In checking on the internet, found partial TSB that indicated same problem with vehicles built late 2006 and early 2007. The TSB did not have a no. on the right up.
Is it possible to get the TSB and/or no. so I can get it reprogrammed at my local dealer.\
Is this something that I will have to pay for since my vehicle is out of 36K warranty.
Thanks for any help.
Tom
0 answers to this question
Can you post a link to the partial TSB you found? I don't see any that look like they apply to what you are describing. Maybe I can get some different keywording off the one you are looking at.
What you have there is not a partial, that is the entire text of the bulliten with only the document ID omitted. I put the bulliten number next to the XXX's in red and highlighted the actual bulliten number by making it red also.
This is what I found.
Document ID# XXXXXXX Document ID: 1915105
GMC Truck Yukon Den
View Full Image
Subject: Articulating Running Boards (Assist Steps) Inoperative (Reprogram Assist Step Controller) #07-08-61-004 - (03/12/2007)
Models: 2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche
, Suburban, Tahoe
2007 GMC Yukon, Yukon XL, Yukon Denali
Built Between November 15, 2006 and January 16, 2007
(with Assist Step Controller P/N 25822021)
Condition
Some customers may comment that the power running boards/assist steps on the vehicle operate intermittently at times or are inoperative. The running boards may stop in mid-travel and remain there until the next key cycle. DTCs B051C22 or B051D22 may or may not have set .
Cause
This condition may be caused by the software in the running board/assist step controller.
Correction
Important: Do not reprogram assist step controller P/Ns 25782667 and 25852622. These modules will not exhibit the condition.
Reprogram the running board/assist step controller, P/N 25822021, with the new calibration.
Important: Use the Pass-Thru method for programming this controller.
Reprogram the Assist Step Controller. Refer to Service Programming System (SPS) in SI for programming information, if required.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
R9731*
Reprogram - Articulating Running Board Controller
0.4 hr
Add
Diagnostic Time
0.0-0.3 hr
*This labor operation is for bulletin use only. It will not be published in the Labor Time Guide.
Read more: http://www.justanswer.com/questions/pklm-j...w#ixzz0Zr9y1by3
Thanks Sparkstech. Is this something that I will have to pay to have done?
GMC Truck Yukon Denali
View Full Image
, Suburban, Tahoe
Condition
Cause
Correction
Labor Operation
Description
Labor Time
R9731*
0.4 hr
Add
Diagnostic Time
0.0-0.3 hr
View Full Image
, Suburban, Tahoe
Condition
Cause
Correction
Labor Operation
Description
Labor Time
R9731*
0.4 hr
Add
Diagnostic Time
0.0-0.3 hr
