Need help on how to pull this motor
I have pulled a fair amount of motors before, plenty of 350's and 454's. My truck I have now is a 1977 Chevy C10 with a 305 2bbl. I have a lifting plate, but it fits a 4bbl intake. I also have the chains, yet my 2bbl intake does not have the outer bolts to connect the chains. I really need help. Thanks
do it the normal way you would without a lifting plate: put bolts in to the holes where accessory brackets go and use bolt holes for the transmission bellhousing on the rear if you have to.
+1
