  • 0
2009 Gmc 1500 "Service 4wd" light
shadow664
Question
Hello, So heres the story, I bought this truck used with 80000 kms on it this past june, It is a 2009 gmc 1500 slt 5.3(LH6)
Before i drove it off the lot, it had a service 4wd light come on, they brought it into the shop and couldnt find the codes, so i said i would bring it back if it happened again
so it only happened a few more times in the summer, but now winter has hit and it pretty much show's up everytime i start the truck. Some times if i restart the truck it disappears, sometimes i can pull the 4wd selector switch and unplug it and plug it back in and it works again
so when i finally had some days off that i could bring the truck into the gm dealer, they told me my bumper to bumper warranty has run out, now i just have drive train warranty left and this would not be covered
so then i brought it to my old place of work(Ok tire) and i used the code scanner and found
C0392 - Rotational Position Sensor Circuit Fault
B0790 - Transfer case Neutral Indicator Circuit
Does anyone have prior experience with this code, I have tried looking around for information about it, but couldnt find anything
So if anyone has had this code or knows what components might be at fault etc and if it should be covered under drive train warranty or anything like that
Thanks for all your help
2 answers to this question
im only posting this for giggles ,but if its bought from a dealer and the light was on then ,ITS THEIR PROBLEM !!!!!
DTC C0392
Diagnostic Instructions
DTC Descriptors
DTC?C0392?01: Rotational Position Sensor Circuit Short to Battery DTC?C0392?02: Rotational Position Sensor Circuit Short to Ground DTC?C0392?08: Rotational Position Sensor Circuit Signal Invalid
Diagnostic Fault Information
Circuit
Short to Ground
Open/High Resistance
Short to Voltage
Signal Invalid
DTC C0392?02
DTC C0392?08
DTC C0392?01
DTC C0392?08
5-Volt Reference
DTC C0392?02
DTC C0392?08
DTC C0392?01
DTC C0392?08
Low Reference
DTC C0392?08
DTC C0392?08
Circuit/System Description
The transfer case shift control module (TCCM) receives input from the transfer case two/four wheel drive actuator position sensor, also known as the rotational position sensor (RPS). The RPS receives a 5-volt reference signal from the TCCM. In return the RPS sends the TCCM a variable pulse width modulated signal indicating the position of the transfer case actuator. The RPS works in conjunction with the incremental position sensor, inside the transfer case actuator, to confirm actuator position. The RPS is more sensitive than the incremental position sensor and is able to indicate to the TCCM the exact position of the transfer case actuator between mode or range changes. It is also able to show how much clutch activation is being commanded at any time.
Conditions for Running the DTC
Conditions for Setting the DTC
C0392?01
The TCCM sees an RPS-PWM voltage that does not constantly change, but remains high, >5.0?V, indicating a short to voltage.
C0392?02
The TCCM sees an RPS-PWM voltage that does not constantly change, but remains low, <0.5?V, indicating a short to ground.
C0392?08
Action Taken When the DTC Sets
Current Mode:
4WD?Auto, 4WD?HI or 4WD?LO
2WD?HI or Neutral
Mode/Range Shift
Conditions for Clearing the DTC
Diagnostic Aids
Reference Information
Schematic Reference
Transfer Case Control Schematics
Connector End View Reference
Component Connector End Views
Electrical Information Reference
Scan Tool Reference
Control Module References for scan tool information.
Special Tools
Circuit/System Verification
Circuit/System Testing
Component Testing
RPS
TCCM
<a href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=1912825&cellId=161474&pubObjSyskey=5351453&from=sm&pubCellSyskey=1257798&deliveryEffectiveDate=Nov+1%2C+2012#N66421">
Repair Instructions
Perform the Diagnostic Repair Verification after completing the diagnostic procedure.
Control Module References for TCSCM replacement, setup, and programming
DTC B0790
DTC Descriptor
DTC B0790?01: Neutral Indicator Circuit Short to Battery DTC B0790?06: Neutral Indicator Circuit Short to Ground or Open
Circuit
Short to Ground
Short to Voltage
Ignition?1 Voltage
B0790?06
B0790?06
B0790?06
B0790?06
B0790?01
The neutral indicator circuit consists of a light emitting diode (LED), a LED feed circuit and a LED control circuit. The ignition?1 voltage circuit is the LED feed circuit and continuously supplies voltage to the Neutral LED. When the Neutral mode has been selected by the driver, the transfer case shift control module (TCCM) provides a ground through the neutral indicator control circuit illuminating the LED. The TCCM tests the neutral indicator circuit for unexpected voltage by monitoring the B+ supplied by the BCM on the ignition?1 voltage circuit by grounding the neutral indicator control circuit for 2?seconds during the bulb?test at key ON.
B0790?01
B0790?06
B0790?01
The TCCM detects 3.4?V or greater on the AWD indicator control circuit when the neutral indicator is commanded ON.
B0790?06
The TCCM detects 1.6?V or less for 1.5?seconds on the AWD indicator control circuit when the neutral indicator is commanded OFF.
Normal operation, the SERVICE?4WD indicator is commanded ON for the remainder of the ignition cycle. Driver is also informed of fault via bulb check.
Diagnostic Aids
Schematic Reference
Scan Tool Reference
Special Tools
Key ON, engine OFF. The TCCM runs a 2?second bulb test on all indicators of the TCSCS at key ON.
Component Testing
BCM
TCCM
Mode
2 High
4 High
4 Low
N
5-V Reference (pin)
11
11
11
11
Indicator Control Circuit (pin)
7
9
10
3
TCSCS
EL49741 Wire Color
2 High
4 High
4 Low
N
Red – pin
4
4
4
2
Black – pin
7
9
10
3
<a href="http://gsi.xw.gm.com/newsi/showDoc.do?docSyskey=1912754&cellId=161449&pubObjSyskey=3132122&from=sm&pubCellSyskey=1921067&deliveryEffectiveDate=Nov+1%2C+2012#N66628">
Repair Instructions
    246.7k
    2.6m
    Conman102
    Conman102
  • Who's Online   2 Members, 0 Anonymous, 364 Guests (See full list)
