2014+ Suspension Lifts
Hey guys! Who is running Bora wheel spacers on their truck with a Zone 6.5” lift? What size spacers are you running so the track width is the same? Can you share some pictures?
Thanks!
I have 1.75” bora’s
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
5 minutes ago, jimmyboy8301 said:
I have 1.75” bora’s
No trimming of the studs correct? They just bolt right up correct?
No trimming with 1.75”
I just wasn’t sure if the 1.75”would be too much. I thought the 1.5” would match the front perfectly but someone told me that with 1.5” need to trim the studs.
The front of our trucks is actually 1/4” wider per side than the rears, add in the 1.5” added track width from the lift and you have 1.75” spacers.
Thanks Jimmy!
Thanks!
Concur with Jimmy, I did the 1.75", no stud trimming. I measured track width as well as where they sat in relation to the fender when I was deciding. There were a lot of recommendations to do the 1.5" because "that's what the lift adds", but I didn't want to trim, and like Jimmy said, the front is slightly wider to start. By track width I measured at 3.25" wider in the front, and from the fenders the front was right around 2" per side. I almost got the 2" spacers but the 1.75 worked out nicely IMO. I have BDS, not zone, but they should be essentially the same thing.
Apparently I never took specific pics after the spacers, but I found a couple to give you an idea. I'm on 18x10 -19 offset.
Hey guys, I don't know if this has been answered. I tried Google and came up with nothing.
My question, am I correct to understand with a 4.5" or 6.5" Zone, I can fit 35s but only fit 11.5" wide tires on stock 20s on my 2018 Sierra 4x4? From what I understand, it has something to do with the stamped steel control arms. Thanks.
Any of you develop any unusual sounds with the lifts.  I have had a 4.5 zone lift for about a year and the last few weeks, it has started to creak a little bit.  Only when on full lock too.  I took it the place that installed it and they double checked everything and it all checks out.  I know its vague, but I have gotten under the truck and had the wife turn the wheel.
Edited by bwilliams22685
Nice looking truck! I ordered the 1.75 Boras and just got them in today. Installing tomorrow! Thanks for sharing, I think I made the right choice!
Time to re-torque
Sent from above
