Does anyone know the gear ratios in the 6-speed tranny?
any year truck do or what ? lmao !!!!
i picked 2011...
Transmission General Specifications
Name
6L45
6L50
6L80
6L90
RPO Codes
MYA
MYB
MYC
MYD
Production Location
Silao, Mexico; Strasbourg, France; Toledo, OH (USA)
Transmission Drive
Rear Wheel Drive
Rear Wheel Drive
Rear Wheel Drive
Rear Wheel Drive
1st Gear Ratio
4.065
4.065
4.027
4.027
2nd Gear Ratio
2.371
2.371
2.364
2.364
3rd Gear Ratio
1.551
1.551
1.532
1.532
4th Gear Ratio
1.157
1.157
1.152
1.152
5th Gear Ratio
0.853
0.853
0.852
0.852
6th Gear Ratio
0.674
0.674
0.667
0.667
Reverse
3.200
3.200
3.064
3.064
Torque Converter Size – Diameter of Torque Converter Turbine
240/258 mm
245/258 mm
258/300 mm
300 mm
Pressure Taps
Line Pressure
Line Pressure
Line Pressure
Line Pressure
Transmission Fluid Type
DEXRON VI®
DEXRON VI®
DEXRON VI®
DEXRON VI®
Transmission Type: 6
Six Forward Gears
Six Forward Gears
Six Forward Gears
Six Forward Gears
Transmission Type: L
Longitude Mount
Longitude Mount
Longitude Mount
Longitude Mount
Transmission Type: 50
Product Series
Product Series
Product Series
Product Series
Position Quadrant
P, R, N, D, M
P, R, N, D, M
P, R, N, D, S
P, R, N, D, M
Case Material
Die Cast Aluminum
Die Cast Aluminum
Die Cast Aluminum
Die Cast Aluminum
Transmission Net Weight (Approximate)
75–78 kg (165–172 lb)
90 kg (198 lb)
95.1–103.7 kg (209.7–228.6 lb)
110 kg (243 lb)
Maximum Trailer Towing Capacity
Refer to applicable owner's manual
