ADVENT OGM1 and rear view cam trouble please help
Hello There,
Have a 13 silverado with a dealer installed OGM1- i tried to add a back up camera today with no luck, i get a message saying no signal when i put in reverse.... I ran the rca plug all the way to the back of the advent.... Spliced the red wire to the light green on the tailight and ground to the black wire on reverse lights..... However do any of the ogm 1 wires need connected anywhere: ie- the reverse switch and parking brake coming from the ogm 1---- anyhelp would be appreciated......
Is your rear camera option on in your settings? does the wire you spliced into turn hot once in reverse? personally I would have ran the wires up and through the floor board grommet on the driver side of truck and plugged into the box under the dash by the brake. The parking brake wire doesnt need to be hooked up to anything as long as you have the over ride option on in your settings and has nothing to do with the rear camera.
