- 0
New Wheel Bearing Hub Assy Install, ABS now activates
Recently Browsing 0 members
248.8k
Total Topics2.6m
Who's Online 15 Members, 0 Anonymous, 881 Guests (See full list)
Question
SAE09
The RH front wheel bearing was shot @ 150k on my 99 K2500 4x4. Easy task to replace, just time consuming.
Using all the correct tools and torque specs as well as care to clean
surfaces prior to reassembly.
Having installed a new Driveworks wheel bearing hub assembly (Advnced Auto Parts), my ABS now activates once my speed drops between 15 & 10 mph regardless of road surface or using the brakes. It does the same in reverse. The ABS does work correctly at various speeds.
Is this something that can occur with an assembly like this in the event the
sensor is not manufactured correctly?
I will be trying a replacement sensor / harness this weekend and if that
does not work then the wheel bearing hub assembly will be replaced.
Any experience with symptoms like this? Thank you SAE09
3 answers to this question
