  • 0
Max Simmons
Valve Adjustment 5.3L
Question
Another question on heads. I purchased a new set of heads for my 2004 5.3L Silverado. They came with a tag saying to valves may need adjustment. I was under the impression that the valves on these engines were not adjustable??? I didn't find anything in my manual about valve adjustment. Any insight on this? Thanks, BTW, very helpful forum here.
Share this post
Link to post
5 answers to this question
  • 0
Usually you just need to make sure they're set at zero lash when the head is all torqued down. Some might be on the tight side and some might be loose.
Share this post
Link to post
  • 0
Since the heads have been re-manufactured, it's probably best for you to measure and verify pushrod length.
The rockers are non-adjustable. You can follow the service manual for proper rocker tightening procedure and torque spec. If you have high miles, I'd replace the lifters while you're at it.
Share this post
Link to post
Answer this question...
