  • -1
service air bag light wont go out
teacup
Question
2006 chevy 1500 5.3l 4x4 air bag light came on check the code, bo100 that's driver side front sensor went to the dealer got 2, installed both but it still have the light on even when we clear it with the scan tool,what else should I be looking for bad ground some where or what. would a fuse do this or a broken wire if so where would you start checking? any help sure would be nice. and thank you!
8 answers to this question
  • 0
you shouldve started checking the diag trouble chart step by step ,,,,,just because the code title says a sensor by name means NOTHING !!! and it bit ya in the behind like a million other people
if ya want the chart and have a scanner ,,,let me know
oh ,,,welcome to trucks !!!! lol
Edited by govtech4
  • 0
DTC B0100, B0101, B0102, B0103, B0104, or B0105
Circuit Description
The inflatable restraint front end sensor utilizes a unidirectional 2-wire circuit. The front end sensor modulates current on the interface to send ID, State of Health, and deployment commands to the inflatable restraint sensing and diagnostic module (SDM). The SDM serves as a power source and a ground for the front end sensor. When the ignition is turned on and input power from the SDM is first detected, the front end sensor responds by performing internal diagnostics and sending an ID to the SDM. The SDM considers the ID to be valid if the response time is less than 5 seconds. The front end sensor continually communicates status messages to the SDM, which determines if a fault is present in the front end sensor circuit. When a fault is detected, the SDM resets the front end sensor twice by removing and reapplying power. If the fault is still present, the SDM will set a DTC.
DTC Descriptors
This diagnostic procedure supports the following DTCs:
  • DTC B0100 Electronic Front End Sensor 1 Performance
  • DTC B0101 Discard Electronic Front End Sensor 1
  • DTC B0102 Incorrect Electronic Front End Sensor 1 Installed
  • DTC B0103 Electronic Front End Sensor 2 Performance
  • DTC B0104 Discard Electronic Front End Sensor 2
  • DTC B0105 Incorrect Electronic Front End Sensor 2 Installed
Conditions for Running the DTC
Ignition 1 voltage is within the normal operating voltage range.
Conditions for Setting the DTC
  • DTC B0100 and B0103 will set when one of the following conditions occur:
    • A valid ID message is not received within 5 seconds of the front end sensor being powered up.
    • Status message is not received.
    • The SDM has failed twice to reset the front end sensor.
  • DTC B0102 and B0105 will set when one of the following conditions occur:
    • The SDM has received an ID message from the front end sensor which does not match the ID stored in the SDM memory.
    • When 2 front end sensor resets are attempted without the correct identification being detected by the SDM.
  • DTC B0101 and B0104 will set when the SDM has received 4 consecutive NOK (Not OK) messages from the front end sensor.
Action Taken When the DTC Sets
  • The SDM commands the AIR BAG indicator ON via class 2 serial data.
  • The SDM attempts to reset the front end sensor.
Conditions for Clearing the DTC
  • The condition responsible for setting the DTC no longer exists.
  • You issue a scan tool CLEAR DTCs command.
  • A history DTC will clear once 255 malfunction free ignition cycles have occurred.
Diagnostic Aids
The following can cause an intermittent condition:
  • A short between the front end sensor signal and low reference circuits
  • High or low resistance in the front end sensor signal and low reference circuits
  • Inspect the front end sensor signal and low reference circuits carefully for cutting and/or chafing
  • Verify that the correct front end sensor is installed in the vehicle
Refer to Testing for Intermittent Conditions and Poor Connections in Wiring Systems.
Test Description
The numbers below refer to the step numbers on the diagnostic table:
  1. Tests the communication status of the front end sensor.
  2. Tests for a short to ground, a high resistance, or an open in the front end sensor signal circuit.
  3. Tests for a short to ground, a high resistance, or an open in the front end sensor low reference circuit.
  4. Tests for a short to voltage in the front end sensor signal and low reference circuits.
Step
Action
Yes
No
Schematic Reference: SIR Schematics
Connector End View Reference: SIR Connector End Views
Did you perform the Diagnostic System Check – Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
2
  1. Install a scan tool.
  2. Turn ON the ignition, with the engine OFF.
  3. With a scan tool, request the SIR DTC display.
Does the scan tool indicate that either DTC B0101, B0102, B0104, or B0105 is current?
Go to Step 12
Go to Step 3
3
  1. Turn OFF the ignition.
  2. If DTC B0100 is current, disconnect the left front end sensor connector. If DTC B0103 is current, disconnect the right front end sensor connector. Refer to Airbag Front End Sensor Replacement.
  3. Inspect both front end sensor and harness connector terminals for damage or corrosion.
Do the front end sensor terminals or harness connector exhibit any signs of damage or corrosion?
Go to Step  4
Go to Step 5
4
  1. If the front end sensor terminals are damaged, replace the front end sensor. Refer to Airbag Front End Sensor Replacement.
  2. If the front end sensor harness connector is damaged, replace the connector. Refer to Connector Repairs in Wiring Systems.
Did you complete the replacement?
Go to Step 13
5
  1. Disconnect the sensing and diagnostic module (SDM) connector. Refer to Airbag Sensing and Diagnostic Module Replacement.
  2. Inspect the SDM connector for corrosion or damage. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 13
Go to Step 6
6
  1. If DTC B0100 is current, test the left front end sensor signal circuit for a short to ground, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
  2. If DTC B0103 is current, test the right front end sensor signal circuit for a short to ground, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 13
Go to Step 7
7
  1. If DTC B0100 is current, test the left front end sensor low reference circuit for a short to ground, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
  2. If DTC B0103 is current, test the right front end sensor low reference circuit for a short to ground, a high resistance, or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 13
Go to Step 8
8
  1. Turn ON the ignition, with the engine OFF.
  2. If DTC B0100 is current, test the left front end sensor signal and low reference circuits for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
  3. If DTC B0103 is current, test the right front end sensor signal and low reference circuits for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 13
Go to Step 9
9
For DTC B0100 replace the left front end sensor. For DTC B0103 replace the right front end sensor. Refer to Airbag Front End Sensor Replacement.
Go to Step 10
10
  1. Reconnect all SIR system components.
  2. Use the scan tool in order to Clear the DTCs.
  3. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 11
System OK
11
Replace the SDM. Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
Go to Step 13
12
For DTC B0101 and B0102, replace the left front end sensor. For DTC B0104 and B0105 replace the right front end sensor. Refer to Airbag Front End Sensor Replacement.
Go to Step 13
13
  2. Verify that all components, connectors and connector position assurances (CPAs) are properly mounted.
  3. Use the scan tool in order to clear the DTCs.
  4. Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
  • 0
problem solved!!!!!!! after doing all the testing and checking I got a bad sensor from the dealer!!! a little p o but now I know how to check for problems, thanks for all the help.
  • 0
Hi Rob.
I noticed your helpfulness on here. Much appreciated.
Do you have a method to check the front end sensor? I purchased two and noticed codes moving around before finding the troubleshooting chart above. I wish I would have looked that up first. It may have saved me purchasing a sensor.
Before I found the chart above, I was messing with my scan tool and got a B0100.
https://goo.gl/photos/TcXx4cFk2gKALGg89
I swapped the sensors side to side and got a B0103.
https://goo.gl/photos/SFNPgoFuDxUzHTAr7
I'd like to check the SDM. Where is that physically on the truck?
thanks
ramey
Answer this question...
    246.8k
    2.6m
    CurtlMarvin
    CurtlMarvin
  • Who's Online   4 Members, 0 Anonymous, 452 Guests (See full list)
