Sign in to follow this
wilsonz71
Torque converter stall?
I'm at a loss for what stall of converter to go with in my truck. I'll be dropping in an lq9 6.0l I got from an 06 escalade soon and feel like I should replace the torque converter and up the stall a bit. Monster trans sais the stock stall speed in my truck is 1650 rpm. any help would be great. trans is a built ss monster 4l65e, 4:10 gears, turning 35s. Not trying to win races, just need it to pull my camper nicely, work well off road, not a daily driven truck, but does still see a fair bit of highway driving. Any ideas?
Share this post
Link to post
I'm just here to ask for a build thread with plenty of details and pictures! :)
Carry on...
Share this post
Link to post
Think if you plan on camming it, nothing less than a 3k stall.
Share this post
Link to post
With towing, high stall is bad.
Share this post
Link to post
X2
Share this post
Link to post
X2
X3 on this.
One thing you may consider doing is replacing the stock flex plate with a race grade SF29 unit, if you are towing, you will NEVER have to worry about flex plate cracks.
The race plates come with longer bolts to compensate for the increased thickness of the plate.
Edited by Gurrzt
Share this post
Link to post
If you get a stall converter go for about 2800 if youre going to tow. Also spend the money on a multi disk
Share this post
Link to post
Thanks guys, lots of good info here. I'm going low stall for sure for towing. If I do decide to cam it it won't be for a while. I go pick up the engine saturday, I'll be sure to take a bunch of pics and start up a build thread.
Share this post
Link to post
If you stall at all go with aftermarket trans cooler. A lot of guys like the TruCool 40k. I like the setup I put on. It costs more, but my trans has been alive a lot longer than it should have
Share this post
Link to post
Regular z71 external cooler not up to the job?
Share this post
Link to post
The SS guys have the same cooler as the z71. Most of them guys get rid of that tiny cooler. My first cooler was larger than the KNP code cooler, and I still went larger.
Share this post
Link to post
Just looked up the trucool 40k. It's like 4x the size.
Share this post
Link to post
Share this post
Link to post
It fits
Share this post
Link to post
A comparison
Installed on a Silverado SS
A stall converter causes the trans to run hotter. Keep in mind that tiny cooler was designed to work on a "stock" application
Share this post
Link to post
