Completed Retrofit - Tuned RX350, Color Changing DRLs, LED Concepts H
Total Build Tally for my 2015 Sierra Denali
OEM Headlights with LEDs
RX350 Non-AFS Projectors
Phillips 6000k Ultinon Bulbs
Hyluxtek 50w Ballasts
Diode Dynamics RGBW DRLs
LED Concepts Outline Halos
LED Concepts Demon Eyes
Oracle Cube Halos
VLEDs V3 Triton
Chrome was stripped and colormatched at the bodyshop for a perfect finish
Amber was removed from headlight
Adapter plate courtesy of Spurshot streamlined the projector retrofit
Truck before lights:
16449_10152850503911084_6376440873762315
Stock lights and DRL
11255020_10153182026536084_3377843867522
Painted Bezels
11295617_10153186890796084_4188060754767
11227036_10153186890826084_2771228934996
Stripping DRLs
11219401_10153188609291084_8488589780537
11201885_10153165576371084_1489066473224
RX350 Projectors Mounted
11206012_10153165575456084_2340966500498
11140401_10153165575801084_3635461379940
11150701_10153165575956084_2229030280240
Projectors and Oracle Halos
11111918_10153188609501084_7124319304310
Lights coming together
11539587_10153294990311084_7276641941276
11692610_10153294990316084_8539897879177
11659257_10153293033746084_2344459459529
11054828_10153293034266084_3536383143401
10985107_10153293034131084_4981349151616
11261937_10153294990201084_8652409742232
Oracle Halos
Grommets and Wiring
Finished Lights
Absolutely brilliant. I wish I was able to turn my mechanical fury down a little from building race cars and trucks so I could do detail work like that. I'd end up opening the light with a hammer, lol. I'm a MECHANICAL engineer, not an ELECTRICAL engineer for a reason. But bravo, sir.
Danger, spurshot made those brackets for you? I got the plastic ones from fast headlights.
Sent from my SAMSUNG-SM-N910A using Tapatalk
The plastic ones from fast are for the FX-R projector. Very strong projector but I wanted OEM and it just so happened that sputshot was doing the same project and he helped me out huge.
Couldn't have done it without him. Amazing fella!
Danger im just curious why you didnt cut open the lense like fast does or mike 1220 did? Any specific reason? I know its a pain in the butt to do it that way.
Not cutting is a better way to do it. It produces a much cleaner looking finished product. By not cutting open the Sierra lights, you can get away with a single 3/8" or 1/2" hole if you prefer on the bottom of the housing so that it look as stock/untouched (including not modifying the dust caps) as you can make it.
Yeah guys I agree. Messed up thing is I already cut the back open on one of them before deciding to try to open the front. Gonna try again to pry open the front. Still on the first one. Lol
I got it open. Tried 260 for 20 min. That dang permaseal hardens back up pretty quick though. Kept putting it back in for 10 min.
OK danger. Second one was ten times easier than the first one because I figured out what I was doing. Kept it hot after being in there for 20min. Pryed all around with the flathead, and then put it back in for 15min. Pulled it right out and began separating it. Came out like a champ. Didn't bend up the second one near as bad as the first. Probably gonna add a little butyl after I'm done and put it back in the oven to heat things up. Then seal her back up.
