2015 Allison Transmission screw on type external oil filter
Hey folks ive heard that theres an external screw on type oil filter on the Allison trans that they say has to be changed at or before 15,000km (9320mi) or it will void the Allison warranty just wondering if anyone has any insite on this prior to stopping by the dealer
Thanks Folks
Garry
Don't know about voiding the warranty...I would change it as it's an 11.00 part on amazon. Keep the receipt and record the mileage and your good to go. Super easy to change as well...
Owners manual says 45,000 miles normal or severe service change filter.
PS - There is no Allison warranty, Allison is no longer part of GM . GM got the rights to build the Allison 1000 Series transmission in GM factories as part of the sale of Allison away from GM. GM installs the Allison 1000 Series into their HD pickup trucks and warranties it, not Allison.
Ok perfect thats good to know and saves me a trip to the dealer to ask a question that they would go into this big explanation thats not needed
Thanks again
Pretty positive the Allison 1000 is still made in Indy at the Allison plant.
They are all built in Baltimore, Maryland. GM owns the plant.
Type: Six speed, rear-wheel-drive, electronically controlled, automatic, double overdrive transmission with torque converter clutch and park pawl Engine range: 6.6L
Maximum Input Torque: 765 lb-ft
Maximum Input Power: 397 hp
Gear ratios: MW7 First 3.094 Second 1.809 Third: 1.406 Fourth: 1.000 Fifth 0.711 Sixth 0.614 Reverse: 4.480 Maximum shift speed 3300 rpm Maximum validated gross vehicle weight: GVW
12,000 lb - 3600 series
11,400 lb - 3500 dually series
9,900 lb - 3500 non-dually series
9,200 lb - 2500 HD series GCW
23,500 lb - 3500 dually, 3600 series
22,000 lb - 3500 non-dually
22,000 lb - 2500HD 6-position quadrant: P,R,N,D,M,1 Case material: die cast aluminum Shift pattern: (3) on/off solenoids Shift quality: Variable bleed solenoid control / adaptive shifts Torque converter clutch: Variable Bleed Solenoid Control Converter size: 310mm (diameter of torque converter turbine)
Fluid type: DEXRON® VI
Transmission weight: dry: 150 kg (330 lb)
Fluid capacity (approximate): shallow pan: 12L (13 qt.) (dry)
Power take off: provision available Pressure taps available: main pressure
Assembly Site:: Baltimore, MD
Available Features:: Tapshift Range Selection Mode
Grade Braking
Cruise Grade Braking
Tow/Haul Mode
Shift Stabilization
Adaptive Shift Controls
Heater Performance Mode
Low Traction Mode
Exhaust Grade Braking
Exhaust Cruise Grade Braking Applications: Chevrolet Silverado and GMC Sierra 2500HD, 3500, 3600 Series
http://www.gmpowertrain.com/VehicleEngines/PowertrainProducts.aspx
All other Allison models 2000 Series, 3000 Series and 4000 Series are built in Indianapolis.
I would change the filter within the first 6k miles or so...Gets rid of the initial wear particles. After that I usually replace them every 30K...
i change mine every 15k as well as most others with allisons, very easy to do but make sure you clean the magnet off good and also fill the filter back up with fluid or you will loose all the fluid that was in the filter.
