K2XX 5.3L Pic Request - Flex Fuel sensor mounted on the frame
Tonight or tomorrow I will be installing the flex fuel sensor used on the K2XX trucks on my 2014 K2XX with the 6.2L. I was hoping someone with a 5.3L and flex fuel could slide under there truck and take a picture of the sensor mounted on the frame and the connectors on each end that go to the fuel lines. I stopped by my local dealer today and they didn't have a single flex fuel truck on the their lot that I could look at for reference. Thanks in advance guys!
  • Replies 76
I am assuming you are going to convert your 6.2 to flex fuel by adding the sensor and a custom tune? I'm surprised there isn't more information on this forum about that.
Flex fuel Sensor part number 13577429?
I will too watch this thread...
I wish there was a thread or how to thread regarding adding this sensor, as I really want to do this and get a custom tune for it.
Yes that is correct. You just need to be careful when you order that part number. It looks like GM also used that part number on earlier version of the sensor that is a different design.
What you want....
What you don't want...
I'm assuming there is no harness to plug into just waiting for us, something will need to be hard wired?
Your assumptions are wrong. There is a plug waiting and holes pre drilled on the frame as well. The biggest deal is tapping into the fuel lines and of course getting a tune.
You have a pic of this?
Sent from Tapatalk App - Samsung S6
Yeah I'm about to leave work in a few minutes. I'll post back with a picture.
Ty Sir.
Ty Sir.
Here are two pictures for your reference. Both pictures were taken while i was underneath the truck from the passanger side. So the parts your looking at are located on the drivers side, on the inside of the frame. If you look about 1 to 2 o'clock of the plug you'll see three holes on the frame. That is where the sensor mounts.
Sent from my SM-G900P using Tapatalk
Ah, thanks! I'm gonna ask a buddy to snap a pic of his 14 Sierra, if he's in town.
You'll be good to go. I did this mod as well, still working on the tuning aspect of it with BBP but plumbing the sensor in and hooking it up is a piece of cake! As far as the rest of the fuel system thing.....it's all identical between FFV or non FFV so no worries there!
Can I request pics of your plumbing?
