POST PICTURES OF YOUR BODY LIFTS (2014+)
Y
Just went down and looked at my truck, everything is on and painted just right. body lift is on and looks great still somewhat of a gap above the front bumper they said they tightened everything as high as it would go it may just be the kit. 516fde37cf33563319e01aa7c453ffe7.jpg5dbdec6fae342eee997f8b37efee11a7.jpg8e0db495ccafa15ca8c35fe83ffffe97.jpg01f081326aa84c5621365fdbff61b802.jpg
Last pic is of the small gap above the front bumper. Does it look normal?
Yours looks about the same as mine. These kits use some of the existing holes then you drill a couple to reattach part of the factory bracket to the new front bumper brackets, If you want the bumper to go up a little you'll have to slot the holes. I've considered doing mine to get the bumper up a 1/4" or so. I've also looked at the factory gap on multiple sierras and it seems to vary from truck to truck even seen a few that were crooked right from the factory. Planning on a full rx350 retro for the headlights, when I have the front end apart I'm going to see what can be done to raise the bumper a bit, I know mine is a bit lower than it was before adding the body lift.
Just got it back today. Already had the RC 2.5 level and just got the 1.5 body kit installed. Any ideas for tires. Size/brand? Thanks
All depends on the wheel offset, diameter and type of tire you want to run. If you keep a factory offset I've seen trucks running 35's with this setup. My wheels are -12 and I have 285/65 18 and they clear fine. I want to go 305 65 18 BFG KO2 but I'm not sure they will clear. 305 60 18 should clear OK but tire choices are limited in that size and BFG doesn't offer it.
Yea I'll keep the factory offset. I've looked at some 35's and leaning towards a 295/70/18 trail grappler. I had the 285/65 on my 07 Chevy and liked them. I talked to a guy in town that actually ran 305/65 BFG on just a level. Looked awesome I just like the aggressiveness of the trail grapplers. Thanks I appreciate the input!
Make sure you post your TGs here when you get 'em!
And some pics of the truck with the 305/65R18s. I've been searching the net and can't find anyone running them on 2014+ with a level. Seems like the perfect tire for 4" of total lift.
Edited by bcbz71
I still haven't taken the plunge with the BL. Could you measure the overall height of your truck on level ground all the way to the tip of the ONSTAR antenna? I really want the 295/70r18 setup with stockers like you, but it HAS to fit in my garage!!!
Sorry took so long to get back with you its about 75.5 inches to the onstar antenna
RC 2.5" front only level
RC 1.25" body lift
275/60/20 nitto G2
I'll get better pictures when I have her all cleaned up
Truck lookin good! I had to loosen the outer mounts on front bumper to adjust the gap a little tighter after I got done maybe try that if it's off to bad, doesn't look bad in the pics
I'm running 295/70r18 on stock z71 wheel, size is great fills wheel well but rubs liner slightly and sway bar at full lock reverse but not enough to worry about your truck looks good post pics when u get tires on!
And some pics of the truck with the 205/65R18s. I've been searching the net and can't find anyone running them on 2014+ with a level. Seems like the perfect tire for 4" of total lift.
I've taken all the measurements and it's going to be close, however from what I've read BFG's tend to run small especially after being mounted spec says 33.5 but if its anything like I've read on other forms they'll probably be about 32.75 to 33 after being mounted. I called tire buyer to ask what could be done if they don't clear and they said as long as you have them shipped to a preferred installer you can send them back regardless of the fact they have been mounted your just out the installers mounting fee which is 17 dollars for the firestone by me. So pretty low risk might cost me 35 bucks to do a tire fitment if they don't work. I tried my buddys KO2's on my truck 275/70/17 on stock wheels and they rode better and were quieter than my AT2's although a 305 might be a different story I'm guessing the wider foot print is going to generate more noise and a squirmier feel.
That's interesting. I just measured mine in the garage, and I'm coming up with 75.5 but I've only got a level with 32" tires. They are really about 30.5 with the weight of the truck on them. I wonder if GMCs are taller??...doesn't seem to make much sense though. Once I go to a 33"+ tire and a 1.5" BL, I'll be at 78.5" total height. I think I will still have clearance though.
Are you talking about BFG KO2 305/65R18? If so, can't wait to see the pictures!
Hey I checked again I parked in a couple spots and used a level off the antenna this time I got one more inch out of it 76.5 to onstar antenna you must have had a tall stock truck lol unless I'm measuring wrong my fender heights are 41 front and 41.5 rear what are yours Edited by z71 chevy
39 front (with 2.5 RC level....1" bottom strut spacer and 1/4" top strut spacer)
41 rear (with RC rear block and Firestone RideRite Airbags at 5 psi on the rear)
53.5 to the bottom of my mirror
So, if I add a 1.5" BL, I'll be 40.5 (front). If I go 34" tire (net 33"), I should go up to ~42" front.
That's all adding up properly, so maybe the GMC cab is taller than the Silvy cab??? I know my hood is taller and different than my buddy's Silvy.
Yeah those would be the ones, probably give them a try sometime in March.
One guy on here I believe full lock is his handle had 305/65/18 I think they were falkens on with just a level, however he had them on a -12 offset wheel and had to cut out a significant amount of metal to get them to clear. I think it was him that replaced them with 33x12.50 Toyo RT's, that set-up looked real nice on his truck.
 Share
  • Similar Content
    • By SubParMechanic
      I have a 2015 Chevy Silverado with a 6.2L. About 2 months ago I had bent a rod on Cylinder 4. I replaced all the rods, cleaned all the rockers, new lifters (even AFM), new gaskets, plugs, and plug wires. After the truck ran fine for about a week, then threw code P0106, which is a MAP sensor code. And for the life of me I couldn't get the code to stop showing up. If the code is deleted the truck runs perfectly fine for about 30 miles, then it throws the code and has a bogged down, flooded feeling. I've checked everything I can think of and don't know where to go next.
      What I've checked:
      Wiring Harness and Ground Connections
      New MAP and cleaned MAF
      Air intake gaskets and filter
      Cleaned Throttle body
      Checked Fuel Rails
      Plugs, Wires
      Compression tests (all at spec or very close)
      No leaks in intake
      All fuses
      After I spent two weeks after work on this thing I decided to take to the shop, they tried a new computer, new sensors, and ran a cylinder leak down test. The truck still is not fixed but I brought it home today because they told me the only option was to send the heads in to be cleaned and new valves. Said the carbon build up was causing this issue but I'm confused as to how that would affect MAP sensor. Especially when compression tests are all right where they need to be. When I replaced the rods I even checked to make sure valves weren't stuck and didn't make contact with head of piston.
      Anything help and am open to all options. My next step is to take a look at injectors and to replace/clean the valves myself.
    • By 01Silverado2wd
      hello gm-trucks commuinty i’m having issues with a smog readiness monitor not completing. any information on this issue would be greatly appreciated. my truck is a 2001 Chevy Silverado LS 1500 with a 5.3L v8 and it’s 4x2. all the readiness monitors complete except the secondary air system causing the truck to fail smog in california. i’ve heard the air pump turn on at cold starts and even replaced the passenger side check valve. also replaced the solenoid that sends vacuum. everything in the secondary air system seems to be operating properly but the monitor won’t complete. i’ve driven 100s of miles and done countless cold starts but no luck. even the smog referee said the system is working properly and i should just drive the truck more. anyone else experience this issue and what did you have to do to complete the monitor? there are no codes stored currently and the truck runs fine. thank you to anyone that helps
    • By Tattoo magic
      I have a 2022 Silverado 1500 four-wheel-drive. The dealer ordered the 2 inch lift kit they offer and I’m waiting for it to come in and have it installed. But I noticed that the kit doesn’t come with upper control arms. Is that going to be a problem?
      (***UPDATE*** )
      so I had the factory lift gm offers installed. When I picked it up, it looked great but as soon as I went to drive it off the lot. I could tell something was wrong it felt completely different. I figured it was just a break in period. But even after a day or two, I was getting crazy bad vibration at low speeds. Took it back. They ended up putting one of the U-bolts on wrong (I have pictures if wanted) they fix that and told me the vibration was gone. I get my keys go to drive away vibrations right back. I turn right back around. this time they have a mechanic ride with me. He clearly hears  an feels a vibration, says somethings wrong so we turned around and he takes it back in. Three hours later they bring my truck back they had to remove the back blocks said there was no taper to them and it was messing up drive line. I got it back and the vibration is still there. (Now annoyed that only the front is lifted and still vibrating). I have them take the whole lift kit off. Put it back to stock. (Now remind you my truck has been down and I’m missing work for 5 days at this point) And after that Whole ordeal, I was done with the truck since I couldn’t have it how I wanted it and decided to trade it in and they made me a good deal on a 2023 5.3 LT.z71
      I know many have gotten this lift installed said it worked out for some reason it did not for me. I’m much happier with the new truck.
    • By Jgardow92
      I have a 2022 trail boss lt that has about 6100 mile on it now. Bought it brand new in may 2022 and it seems like the drivers seat leans to the left towards the door. Almost feels like Im gonna fall out of it and no matter how I adjust it it seems the same. Visually it looks like it sits level and is fine. Is it possible something is broken inside like the frame? I would assume the frame would have to be sturdy. Is there any place that sell a better bottom cushion?
    • By drmilesbennell
      Hey all,
      I have a 2022 Sierra SLT with passive entry locks on the front handles. Does anyone know if I can easily add passive entry locks to the rear handles? Acquiring the actual handles would not be the issue but I'm wondering if there is a harness (or whatever powers the front passive entry buttons) in the rear door to begin with. I know they come standard on Denali, so was thinking GM might just leave the wiring in the door for different trims but not include the passive handles all around. As I type this, though, I'm sure there's programming that needs to be done but figured it was worth a shot - because why not!
      Any help is appreciated, thanks!
    242.1k
    1.4m
    Mitchell Brine
    Mitchell Brine
