GoRhino RB10 Install (2015 GMC Sierra Double Cab)
Good day folks, long time lurker here.
I received my RB10's in the mail today based on all the good reviews from this forum. I unpacked everything, verified that all parts were there and all that fun stuff. When it came to Step 1 on the install where you locate the bracket mounting points, it says to screw the bolt/lockwasher/flatwasher in through the "pre-threaded hole". I located the proper hole for the front bracket, however, I noticed that it was not pre-threaded, and neither are any of the other holes for any of the mounting points.
Can someone offer me advice on this? I am almost 100% sure that I located the proper holes.
Thanks!
  • 3 weeks later...
Does the kit come with speed nuts? It's like a clip with a threaded piece on one side? I know I put a set of steps on a friend's ram and that's the way his worked. Put the clip onto the hole and screw the bolt in.
I just installed mine on a 15 Chevy CC
It came with those speed nuts, looks like a paper clip with a nut on one end and slides into plce after removing the plugs on the rocker panel
The front mounts on the rocker panel are threaded
PHOTO'S PLEASE
