  • 0
Location of fuel filter on a 2004 Yukon XL 8.1L gas
Sickboy73
Question
Anyone know the location of the fuel filter on an 04 Yukon XL with the 8.1L gas engine?
3 answers to this question
I own the same generation '01 Tahoe and the filter is on the driver side chassis, but not so for the '04 Yukon. In accordance with GM #PI001875A - the gas powered V-8 engines have a lifetime filter built into the fuel sender inside the tank and thus is not serviceable separately.
Thanks very much for the info. I will check under the yukon and find out which one I have.
If I remember correctly 04 was when they went to the life time filter in the tank. But some of the production units had external filters. That being said look along the drives side frame rail near the transmission cross member. If there isn't one there then you have the one in the tank.
