New 2005-07 6.6 Duramax 2500 3500 K&N Cold Air Intake Kit
gn4life
Brand New K&N FIPK Cold Air intake system for Chevy GMC 2005, 2006, 2007 Silverado Sierra 2500 or 3500 Duramax Diesel. fits Dually too. HD. Buyer is responsible to double check fitment.
Brand new item. Just an open box . Never used or installed. Don't be fooled by generic or lesser brands.
"K&N 57 Series FIPK intake kits are designed to eliminate air path restriction and deliver a massive amount of air into your engine, resulting in more power! These kits start out with an extra-large, conical shaped high-flow air filter that captures and holds more dirt and flows more air than a standard K&N OE replacement filter. The filter is attached to a rationally molded HDPE tube that's specifically shaped for your application to reduce turbulence and accelerate airflow into the engine. High-strength adapters connect the K&N 57 Series FIPK intake to the engine for a secure and lasting fit. If you're looking for the best-flowing, best-filtering high performance street legal air intake system, then K&N 57 Series FIPK kits are the way to go!
This is the easiest, quickest, and most effective way to bolt -on real horsepower and better fuel mileage. Simple do it yourself install.
K&N CLAIMS A GAIN OF + 22.04 HORSEPOWER AND +40.58 FOOT POUNDS OF TORQUE
This kit sells for $300 after tax.
FIRST $190 OR BEST OFFER TAKES IT!!!! WONT LAST LONG !
Can ship depending on zip code
