Just a quick heads up that I am going to be running a special on our Catch Can Systems.
UPR Plug n Play™ Dual Valve Catch Can with UPR Plug n Play™ Clean Side Separator.
Normal Retail is $399.99 for the UPR Plug n Play™ Dual Valve Catch Can System + $69.98 for the UPR Pro-Series™ Check Valve Package
We are offering the complete system including the NEWEST Patented Plug n Play™ CSS - Clean Side Separator
$349.99 as a limited time offer for trucks with Factory Air Intakes.
$379.99 as a limited time offer for trucks equipped with Cold Air Intakes.
This is over $120 savings off either kit for a Special limited time offer!
14-17 GM CHEVROLET GMC TRUCKS 6.2L UPR Plug n play™ DUAL VALVE CATCH CAN CSS
5030-218-CSS Full system - Satin Finish
5030-218-CSS Full system - Black Finish
5030-219-CSS Full System for CAI - Satin Finish
5030-219-1-CSS Full System for CAI - Black Finish
14-17 GM CHEVROLET GMC TRUCKS 5.3L UPR PLUG N PLAY™ DUAL VALVE CATCH CAN CSS
5030-168-CSS Full system - Satin Finish
5030-168-1-CSS Full system - Black Finish
5030-220-CSS Full System for CAI - Satin Finish
5030-220-1-CSS Full System for CAI - Black Finish
UPR PLUG N PLAY ™ Pro-Series™ BILLET CHECK VALVE - 0PSI CRACKING 0-100PSI OPERATING PRESSURE
5044-03 5/8 Check Valve - Black Finish
UPR Catch Can Systems have the best materials from the $100 in Insta-Grip Braided Hoses to the OEM style UPR Plug n Play™ Fittings and the Patented Multi-Stage Multi Chamber Internal Design on our Billet Catch Cans and the Exclusive Patented Clean Side Separator. No other Catch Can System can even come close to the quality or value you get with our Catch Can System.
We don't use cheap rubber hoses and tell you to push the hoses on without clamps or fasteners. Or fill our Catch Can with cheap steel wool that sheds and can be sucked through your engine. No welded designs with parts tack welded together and we don't try to sell you additional o-rings for a system that should come with them and last or be covered by the manufacturer.
Feel free to PM me for details or to get setup with this deal.
Joe
Edited by joeupr
Hi Joe,
What is the total shipped price of 1qty 5030-168-1-CSS Full system - Black Finish to 40356?
Does it come with check valves and the upgraded ones are $69 or does it not have any to begin with?
Thanks,
Mike
  • 4 weeks later...
Hi Joe,
What is the total shipped price of 1qty 5030-168-CSS Full system - Black Finish to 85053
Does it come with the upgraded billet series check valves that are an $69 upgrade
Thanks,
Ken 623-696-6462
Just a quick heads up that we are extending our GM-Trucks Catch Can special offer.
UPRproducts GM Catch Truck Can Special Offer !
Joe
 Share
  • Similar Content
    • By dvzzz
      SOLD
      The kit includes our billet aluminum check valves. If you are generating more then 12# of boost, you should opt for our high performance check valve. You will only need one to go on the intake manifold side of the system. The other side will still utilize the standard check valve.
       The Standard hose is Gates Push-Lok. This is a high quality hoses cut to fit Tahoes, Yukons, etc. You can replace hoses for $10 to get different lengths.
      https://rxcatchcans.com/ols/products/tracy-lewis-signature-series/v/TLP202
    • By Todd Phillips
      Was wondering if anyone else is having issues with upgrading their OEM wheels?ive got a 2021 LT 2WD with 20” tires and wheels and wanted to change over to the High Country wheels.
      keep hearing that they won’t fit? Anyone else aware of this issue? Something to do with the brake calipers or wheel liners???
    • By Ryan Amey
      Hey everyone,
      I bought a 2014 Sierra 1500 back in September that was perfect EXCEPT it didn’t come with the oem brake controller. So I contacted my local GM dealer and gave them my vin. They looked up my truck and verified that it was built including the trailering package. This is important because I’ve seen that your trucks computer has to be programmed to accept the oem trailer brake controller, the piece isn’t just plug and play. So I verified this with the dealership.
      *I’m really thrown off that my truck has everything in the trailer package for that year except for the brake controller*
      I purchased an OEM piece from another GM dealer on eBay, ACDelco and everything. Plugged it in and haven’t received an alert but I also can’t tell if it’s working. I’m going to try plugging a trailer with brakes in and see if anything changes or if the controller does anything. But from what I’ve seen I should already see a new info page for the brake controller.
      I’ll update the thread later whether or not it worked, regardless I’ll leave the thread up in case anyone else is in the same boat. If anyone has suggestions or advice it would be much obliged.
    • By David209
      Does anyone know where I can find these steps for a Silverado? I believe they are factory steps but I can't find any online.
    • By Coleman71
      I sold my 2017 GMC Sierra 6.2L. I pulled my UPR Catch Can setup off before trading it in. 2014-2018 Chevy Silverado GMC Sierra 6.2L UPR Dual valve oil catch can system with Clean side separator, plug in play with billet valves. Can also work with 5.3L with a different throttle body hose. I used this setup with an aftermarket cold air intake system installed. I no no longer need this, sold my truck. Paid about $600 new from UPR. Has drain valve installed onto catch can. Can meet in Hesperia or San Bernardino, CA area or I can ship within the states. I have more photos upon request. I couldn’t include them on this post because of upload size. Asking $425
    235.3k
    1.4m
    Bob_O
    Bob_O
