Radio won't turn off when opening door key off
Hey guys I have a 2004 Silverado 2500 duramax that when I shut the key off and open the drivers door the radio stays on. It turns off if I open the passenger door like it should. I replaced the drivers door latch assembly but it still does the same thing. Any ideas where to look? I assume it must be a broken wire somewhere or faulty bcm. Thanks for any help
Wire from the door latch through the door jam conduit . Could have an issue at the conduit. I forget the color of the wire. What color was the wire at the door latch? Can you run a window up and down with the DS door open after you stop and shut off and get out as well?
