2008LMGvortec Posted September 7, 2017 Share Posted September 7, 2017 Truck: 2008 Silverado 1500 5.3 LMG engine First, is a 5.3 LMG engine classified as a Gen III or IV LS engine? Would this fit my Truck? Massive Speed Engine MADE IN USA! Lift Plate GM LSX LS1 Hoist Picker Crane 4.8 5.3 5.7 6.0 6.2 7.0 Gen III IV LQ4 LS2 LS3 LQ9 LS What is the best way to remove an engine? I see in the FSM it says to use a J4179 (lift bracket). I see there are lift plates like the one above available. is there a place that the attached lift chain can be safely bolted on without the J4179 lift bracket? So which of the following options are best for my application: 1) Just a lift chain (such as the one attached) bolted to the engine. 2) J4179 lift brackets with a lift chain. 3) Lift plate. Quote Link to comment Share on other sites More sharing options...
Supreme Pizza Posted September 7, 2017 Share Posted September 7, 2017 I'm not sure if this technique will work on a Chevy, but its definitely the fastest way to remove an engine. 1 Quote Link to comment Share on other sites More sharing options...
swathdiver Posted September 9, 2017 Share Posted September 9, 2017 The LMG is an iron block, Flex Fuel, Gen IV motor. Quote Link to comment Share on other sites More sharing options...
Charles_Colfax Posted January 3, 2019 Share Posted January 3, 2019 BumpSame question. I have the engine hoist. And my 06 L59 iron block 5.3 is coming out very soon as part of a "Heartbeat" transplant. Sent from my moto g(6) using Tapatalk Quote Link to comment Share on other sites More sharing options...
sefiroxx Posted January 5, 2019 Share Posted January 5, 2019 Shade tree mechanic: Bolted the chain directly to the block - probably should have gotten brackets as the side pressure on the heads or valve cover might have shifted a gasket.Had to remove the upper front end (radiator etc) to clear enough room for the hoist. Engine was too heavy , had to add 100 lbs (off screen) to counter balance. Quote Link to comment Share on other sites More sharing options...
swathdiver Posted January 5, 2019 Share Posted January 5, 2019 Replace Gen III motors with Gen III motors. LM7, L59 and L33 are all interchangeable but have different camshafts and programming. Quote Link to comment Share on other sites More sharing options...
