Jmiller11331 Posted October 7, 2017 Author Share Posted October 7, 2017 (edited) I just want to clarify to be safe because this is my first time wiring a resistor and leds.... So for the front I need x2 6ohm-50 watt resistor for each headlight (turn signal) and in the back at the tail light (turn signals), I need a total of x4 3ohm resistors which is one for each turn signal bulb right? Sent from my iPhone using Tapatalk Edited October 7, 2017 by Jmiller11331 Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 7, 2017 Author Share Posted October 7, 2017 For the front, you only need 6 ohm - (50 watt). If you are doing rears also, the rears need to be a 3 ohm. There are 3 ohm (50 watt) and 3 ohm (100 watt). Either 3 ohm will work for the back. If you’re only doing the front, 6 ohm - 50 watt will be fine. Sent from my iPhone using Tapatalk ok so if I do all turn signals (front and back) I need x2 6ohm for front and x4 3ohm 50watts for the back? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
pgamboa Posted October 7, 2017 Share Posted October 7, 2017 x2 - 6 ohm for the front, x2 - 3 ohm for the back. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
pgamboa Posted October 7, 2017 Share Posted October 7, 2017 Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 7, 2017 Author Share Posted October 7, 2017 Sent from my iPhone using Tapatalk ahh ok thank you I misunderstood!! One more question and I'm done being stupid lol... how do you wire one 3ohm 50watt resistor to two bulbs? Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 7, 2017 Author Share Posted October 7, 2017 I just figured I needed x4 because I read you need a resistor for each led bulb you install Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
pgamboa Posted October 7, 2017 Share Posted October 7, 2017 ahh ok thank you I misunderstood!! One more question and I'm done being stupid lol... how do you wire one 3ohm 50watt resistor to two bulbs? Sent from my iPhone using Tapatalk No problem. The tail light itself has only one turn Signal circuit wire running both bulbs and needs to the 3 ohm resistor. The Tail Lamp itself will manage both bulbs. So you need to splice the resistor into the turn signal wire and ground. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 8, 2017 Author Share Posted October 8, 2017 For some odd reason I can't find a 3ohm resistor anywhere Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
pgamboa Posted October 8, 2017 Share Posted October 8, 2017 For some odd reason I can't find a 3ohm resistor anywhere Sent from my iPhone using Tapatalk Cutequeen 2PCS 100W Watt 3 Ohm Aluminum Case Wirewound Chassis Mounted Resistor (pack of 2) https://www.amazon.com/dp/B01N0XZTGB/ref=cm_sw_r_cp_api_qhO2zb6HG8P70 Sent from my iPhone using Tapatalk 2 Quote Link to comment Share on other sites More sharing options...
Sour_Squirrel Posted October 8, 2017 Share Posted October 8, 2017 If you have two 6 Ohm resistors you can connect the two in parallel giving it an overall resistance of 3 Ohms. Ohms Law: two resistors of equal resistance in parallel gives the effective resistance of half of one resistor. R (total) = (R1 x R2) / (R1 + R2) =(6 x 6) / (6 + 6) = (36) / (12) = 3 Ohms 1 Quote Link to comment Share on other sites More sharing options...
caskey_b Posted October 9, 2017 Share Posted October 9, 2017 (edited) assuming for the 2014 and 2015 silverados it would take 3 ohm resistors for both front and back then correct? since there are 2 turn signal lights in each headlights? PGAMBOA... the wiring diagram you listed for the 2016+ the same for my 2014? Edited October 13, 2017 by caskey_b 1 Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 12, 2017 Author Share Posted October 12, 2017 Where do I safely put the resistors so I don't burn my truck to the ground or damage anything??Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
pgamboa Posted October 12, 2017 Share Posted October 12, 2017 assuming for the 2014 and 2014 silverados it would take 3 ohm resistors for both front and back then correct? since there are 2 turn signal lights in each headlights? PGAMBOA... the wiring diagram you listed for the 2016+ the same for my 2014?Pretty sure they are the same. But will double check. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 12, 2017 Author Share Posted October 12, 2017 So on the driver side I've installed a resistor to the turn signal and ground and I still get hyper flash?? What could I have done wrong here?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Jmiller11331 Posted October 12, 2017 Author Share Posted October 12, 2017 Got it Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
