Calibrate the outside temperature sensor?
Try pressing the AC and Recirc buttons at the same time.  That has been the behind-the-scenes 'instant update' fix on the outside temp sensors for GM vehicles for many years now.
It seems the General has the computer programmed to always let the sensor temp go down, but never to go up unless a list of factors are met (such as driving at highway speeds) to prevent underhood heat from causing an erroneous reading (go figure).
On my truck, a lot of the time, especially this time of year, the temp reading will get stuck at a cold morning temp (say like 32F) and then if it gets 60 in the afternoon, if I am just driving short trips around town, it will not let the Auto HVAC work correctly until I do one of those 'instant resets'.
Edited by MaverickZ71
Quote
The scan tool has the ability to update the displayed ambient air temperature. To update the ambient air temperature display on the HVAC control module, perform the following procedure: Turn ON the ignition. Simultaneously press the A/C and Recirc switches for 5 seconds.
Edited by newdude
On ‎12‎/‎21‎/‎2017 at 1:52 PM, sdeeter19555 said:
Perfect, I will give that a try. This is the wife's Equinox...can't even remember what the dash layout is.
Steve
2012 2500hd 6.0l
That may change things...however that procedure might work still.  What year Equinox is it?
Edited by newdude
The reset procedure "could" work and might still be worth a try...
Looking at the Equinox however, the outside temp sensor has no..."direct" relation to the HVAC control module.
Quote
Outside Air Temperature
The outside air temperature can be accessed through the driver information center Trip/Fuel switch function. The driver information center shows the outside air temperature as a damped value. The time and rate of the temperature update is based on an algorithm in the instrument cluster. Factors such as last temperature reading, current temperature reading, length of time the vehicle was off, current vehicle speed, and the distance driven effect when the displayed temperature is updated. To get the vehicle to display the most accurate temperature faster, drive the vehicle. Constant moving traffic will update the display to the correct temperature more quickly than stop and go traffic.
The instrument cluster monitors the ambient air temperature sensor with a low reference circuit and 5 V signal circuit. The instrument cluster monitors the voltage drop across the sensor, which is proportional to temperature. When the ambient air temperatures are cold, the resistance of the sensor is high and the voltage signals are high. When the ambient air temperatures are hot, the resistance of the sensors is low and the voltage signals are low. The instrument cluster converts the voltage value to a temperature value of Celsius or Fahrenheit that will be displayed by the display.
I would not rule out a faulty sensor or poor terminal tension (worst case bad cluster) because of its setup.  Even looking at the schematics for the HVAC and then the sensor itself, the only schematic the sensor shows up in is the Instrument Cluster schematic.  From the IPC, the IPC sends the information to the ECM and then to the HVAC, so HVAC is just getting the information on temperature from other modules.  Its a green/white signal wire and yellow 5v reference wire that make up the plug for it, and they trace right to the IPC.
Edited by newdude
  • 1 year later...
I drive a 2016 GMC sierra pickup
I found a site that said to drive 20mph for over 5 minutes straight will reset the temperature gauge on your dash. I had used a super chip to change a few things on my truck and it messed up the temp gauge so I tried it and it worked !!!!
Edited by jas 2016
  • 7 months later...
  • 1 month later...
  • 1 month later...
Anyone come to a fix? I'm having the same issue on my 2010 Silverado LTZ. Tried replacing the sensor. DIC still reads WAY lower. I mean on vehicle start it tells me to watch for ice on roads... It's in the 90's. :? Haven't tried tracing to the CM. The reset button configuration will sometimes work. DIC sometimes will also read "---"; as if there is not outside temp. AC is connected somehow. When the ambient temp is lower than AC temp, AC blows hot.
Any better ideas would be greatly appreciated.
  • 10 months later...
Having the same issue on my 2010 Silverado with manual HVAC and without dual zones? Any luck with a resolve? I'm getting ready to replace the dash control module because I can't get the actuator doors to reset either with the "pull the fuse" method. Any help would be great before I keep throwing money at the problem.
  • 1 month later...
 Share
