Brake Lights Wount Turm Off
Hello i have a 99 desiel suburban and the brake lights will not turn off. Ive taken out the fuse and relay and they still wount go out untill I directly disconnect the battery. The crouse controll also stopped working at the same time. The right turn signal relay wount fire but the left works fine. The hazord lights also stopped working.
More than likely it is the brake light switch has gone bad, I've had them leave the brake lights on all the time and I've had them never turn them on.  But if the cruise is not working I'd bet that is what you need.  :jester:
