Sign in to follow this
ArnottInc
Arnott Introduces Premium Eibach Front Shocks for '00-'06 GM SUVs
Arnott Air Suspension Products is pleased to announce the company is offering a premium Eibach Front Shock (SK-3062) for 2000-2006 GM SUVs (GMT800 Chassis) equipped with Autoride (Z55 RPO).
Eibach Pro-Truck shocks use a high pressure 46mm monotube design that resists fade through even the toughest terrain. The Eibach replacement shock fits the front left or right side and delivers enhanced stability, tight damping response, plus excellent vehicle control and comfort. Driving a vehicle equipped with Eibach shock absorbers is an exhilarating experience. Arnott includes a sensor designed to plug into the auto-damping system and eliminate dash panel error messages.
NOTE: THIS PART SHOULD BE REPLACED IN PAIRS.
Features:
•    Eibach Nitrogen Gas-Charged Monotube Shock
•    Protective Dust Boot for Longer Life
•    New Upper Bushings & Mounting Hardware
•    Installation Manual & Video Available
•    Made in the USA
Additional Aftermarket Innovations for GM Vehicles
The featured new aftermarket Shocks for GMC and GM SUVs are high-quality, cost-effective solutions for GM SUV owners concerned about failing OE air suspension parts leaving them with expensive and recurring maintenance problems. 'The Arnott Advantage' adds exceptional value to some of the most sophisticated air suspension components available. In keeping with the GM tradition of quality and performance, Arnott continues to introduce its own products and designs to replace failing original equipment. See Arnott's impressive array of additional, innovative new and remanufactured aftermarket replacement parts for GMC vehicles Here. See Arnott offerings for Cadillac Here. See Arnott offerings for Chevrolet Here.
Share this post
Link to post
  • Similar Content
    • By IronVilkas
      Hey all,  I just purchased an Eibach Pro truck kit with springs for my 2017 . So I will be leveling out my truck to at least 2.5inches. I am wanting to get some UCAs to go with it and do it all in one go and have the angles in check.
      I am looking at:
      Freedom Offroad
      Kryptonite
      Cognito
      I really like the Kryptonite/Cognito since they use the bolt in balljoint.
      I want to stick with regular balljoints instead of the uniballs and something ~500 bucks or under. Any other brands I should look at? Currently Im not sure what type of gm UCAs I have. Is there anything else I should look out for? I will be running stock 17in rims for awhile before new wheels/tires are in the budget.
      Thanks in advance
    • By 5UCKM3510W
      I know the 6112s are semi-new to the community. My question is what would be the lowest possible notch I can install these and still have enough clearance to fit 275X 65R 20 KO2s. I’d imagine the notch settings are similar to the 5100s accept there is 1 extra notch I believe. I have been searching online for the past week and cannot find anyone that confirms the lowest possible setting to fit these tires. I know I can install them at the highest setting and fit just fine, But I am trying to keep rake in the rear due to occasional towing and i do not want to add a leveling block to the rears. I was thinking the third notch (1.25” of lift) would work but I’m not sure if It will get rubbing.  Does anyone have any idea on this? I currently have a 2.5 inch leveling spacer but do not want to install it when I switch to the Bilstein 6112s. Thanks!
    • By SoonerTA
      Hey everyone, I have been reading through the forum and was going to post this in the “leveling kit” thread but like a lot of questions that have been asked I didn’t want it to get lost in the 475+ pages.
      I have a 2017 Silverado 1500 4x4 LT.  I have been putting off installing a leveling kit till I needed tires and the time has come.  I’m looking at the Eibach Pro Truck Kit with Rough Country 2” rear blocks.
      After reading the leveling kit kit tread I’m a little confused.  I have the stock 20” High Country wheels on my truck and really like them.  Can I go to a 275/60/20 or larger tire?  I don’t want to do a leveling kit if I can’t get a larger tire ti fit and the rim rubs the upper control arm.
      Thanks for for all your help in advance.
    • By Waterfowler41
      SCROLL TO BOTTOM FOR MY FEEDBACK ON THE KIT
      I purchased the Eibach Pro Truck lift kit the other day so below is a quick how to on the process and some initial feedback I have on the kit. My truck has 75k miles and I knew before purchasing anything I had a blown rear shock.  I wanted to lift my truck higher so instead of purchasing OEM equipment and adding more rough country spacers (already had a 2" lower up front), I saw the Eibach kit.  It included everything to complete a reasonable 2.5" lift AND included new springs for less than $600.   From my tuner days, Eibach was the go-to for lowering springs, I assume they know what they are doing plus they are American made, can't go wrong. The struts are adjustable like Bilsteins so this was the best option for achieving the lift I wanted.  With the Eibach springs and the struts at their lowest setting, my truck would be 2.5" higher according to the instructions.  Also, the rear shocks in the kit, safely handle a +1" lift in the rear. This is what I wanted!
      Since I was already touching every other suspension component, I figured I might as well add the 2" rear blocks I've been eyeing so I bought those direct from RC.
      Truck set up before project:
      20" wheels, Falken AT3W 33" tires, RC 2" lower spacer with stock struts and shocks one of which is completely blown. The ride was sloppy, pulling into driveways or other major bumps my truck was rocking and rolling, signs my stock set up was done.  I would wince before hitting large bumps on Chicago expressways knowing my cage was about to get rattle.  The 20" wheels and heavier tires aren't helping but the dampers needed to be retired.
      Purchased parts:
      Eibach Pro Truck Lift kit: E80-23-006-02-22
      Includes new springs, new monotube struts, and new monotube rear shocks.  Also includes new king nuts for struts and bump stop collars for reusing OEM bump stop.  https://eibach.com/us/i-8809-pro-truck-lift-system-stage-1.html
      Rough Country: 6532 (2" rear blocks)
      Includes new u-bolts, washers, nuts, and 2" tapered rear blocks No link, this is the rear blocks from their leveling kit, you have to order over the phone.  Side note, RC folks are REALLY nice on the phone.   If your are uncomfortable working on compressed springs do not attempt the strut disassembly yourself.  Take them to a shop.  I've done several spring projects in my life and understand how dangerous they can be.  Be safe and take the necessary precautions and where the right PPE.  If the compressors fail, they should fail in an open area, not in front of you. Prepare for the worst, hope for the best. I am not responsible for misuse of the below info.
      Important tools:
      Eye protection and hand protection Pneumatic gun Spring compressors  pry bar jack and jack stands Sockets 10 mm and 15 mm all the way up to a deep 22 mm Wrenches 15 mm all the way up to 22 mm A friend, loved one, kid, someone to help. I did this work by myself and it took me probably 6 hours in total, would've been half that with a second set of hands.    Before you do any suspension work, always take measurement from fender to ground or from fender to top of wheel.  This gives you baseline measurements to calculate your final lifts.
      Rears (blocks and shocks):
      1. Jack your car up on both sides.  Put on jack stands.  You want the rear axle to drop straight down.  Only doing one side at a time will be an issue, I learned the hard way.
      2. Doing one side of the truck at a time, remove the upper shock bolt (the nut is welded, just remove bolt) and the bottom bolt/nut.  Shock should pop right out with some love. 3. Place a car jack under the differential.  Remove the (4) 21 MM bolts on the factory u-bolts.  Again only on one side at a time.
      3. SLOWLY lower the rear differential to allow enough room to remove the stock blocks.  Watch your brake lines,  you have some play but not too much.
      4. Before installing the new block, clean the alignment pin and hole on your truck.  Mine had a lot of dirt and salt.  A wire brush cleaned it right up.  I also sprayed it down with WD40 for good measure.
      5. Once the block is installed and lined up, slowly raise your diff back up.  If your blocks are tapered make sure the taller side of the block is closer to the rear of the truck.  Install the new u-bolts and torque the new 22 mm nuts down in an alternating pattern.  Old block next to new blocks below.
      6. Install the new rear shocks, start at the top then do the bottom.  I had to compress the shocks about 1/2" to get the bottom bolt in.
      7. Repeat on other side then your done.
      I took the truck for a quick test drive to test out everything.  No shutter, no issues. Picture below of my old shocks next tot he new, one looks blown...
      Time for the fun part, the fronts!
      Fronts (struts and springs):
      1. Unbolt the 3 nuts on the top of the strut.  Easy access through the engine bay.  You can remove these before the car is lifted without issue. Leave the outside nut hand tight to prevent your strut from dropping out.
      2. Jack up one side of car and remove wheel.
      3. Unbolt the sway bar end link, tie rod end, two bolts on bottom strut mount, and the upper control arm ball joint.  The UCA will need a BFH (code for hammer) to help it out. Leave the nut finger tight so the UCA doesn't shoot out of knuckle right away.  Some people say you can do this without removing the UCA but I just couldn't see how that could be done in my application.
      4. If you're by yourself place a car jack under the knuckle, remove UCA ball joint nut and slowly lower front hub assembly, there should be plenty of room to remove the strut now.  I used a jack stand to hold the hub assembly while I unscrewed the top nut on the strut and carefully remove it.  Once the strut is out, loosely reattach the UCA to the hub so you can leave it for a while.
      5. With a permanent marker, draw a line down the strut assembling marking everything.  The line should be on the outside face of the strut assembly.  This is your index line, when you transplant these pieces to your new strut they should all line up.  If they don't you messed something up.
      6. Now the dangerous stuff, install your McPherson spring compressors on the stock spring, try to grab coils that are far from each other as the spring will be easier to compress. Compressors should be 180 degrees from each other to ensure even loading.
      7. Put on all your PPE, say a pray, and start tightening the spring compressors until you see a gap between spring and strut per mounts. Treat loaded springs like a gun, never point it at anyone and try not to drop it, jostle it, anything that could affect the compressors grip.  Personal note, when I am doing dangerous stuff in my garage I either text someone letting them know what I am doing and text them after I am done or tell my wife if shes inside to check on me occasionally.
      8. After you remove the king nut, open up the compressors, you can toss the springs. You will need to remove the upper assembly of the strut (top mount, bracket, spring boot, and bump stop).  You will also need to remove the lower spring perch.  Do this by gently tapping the perch towards the top of the strut to release it. PB blaster helps speed this up.
      9. Prepare the Eibach struts. These are adjustable to dial in your final ride hide.  In my application, when used with Eibach springs, the bottom level (lowest setting) will achieve a 2.5" lift up front. Snap ring was moved into the bottom grove and collar installed.  The lower perch from OEM strut was installed.
      10. There is a metal collar inside the yellow bump stop, pull this metal piece out and replace with the one supplied by Eibach.  The shaft is bigger on Eibach struts so the collar needs to be upsized.
      11. Dangerous part 2, install the compressors on your Eibach spring.  Again try to grab coils that are far apart to ease the compression process. I believe the springs needed to be compressed 1/2" to fit on the strut.  This was the most nerve wrecking part of this project.  The compressors have seen better days.  Those bends are pretty ugly.
      12. Once compressed start lining up the strut, inside rubber boot, bracket, and top mount.  Your line you drew earlier should all line up with the outside face of the strut. Make sure the bottom of the spring is fully seated on the perch plate.
      13. Install top metal spacer/washer from OEM strut and new king nut provided by Eibach.  Tighten down nut then your good to unload the springs. Once the springs compressors are removed the scary part for that strut is over.
      14. Remove the nut on the UCA and reinstall your strut.  Have at least one bottom strut mount bolt available so once you get the strut lined up, you can throw a bolt on the hole to keep things in place.
      15. Reverse the beginning steps with the reassembly of the hub parts.  You'll will need a pry bar braced on the spring to hold the UCA down firmly into the top of the hub so you can tighten the nut without the ball joint spinning.
      16. Repeat on other side.
      17. Take your truck for a quick test drive, if no noises or issues, take in for an alignment.
      18. Take final measurements to confirm relatively even lift.  Drivers side may be lower due to gas tank.
      Final thoughts on the upgrade:
      I am absolutely in love with the kit.  I've been putting off replacing shocks for a while, so glad I finally did this project.  Dare I say, Eibach MDFA? (Made Driving Fun Again...) Like I mentioned above, I was beginning to notice I was wincing before hitting big bumps because of how loosey-goosey my suspension had become since I bought it. The Eibach kit firmed up the ride noticeably. At slow speeds I do feel small bumps which is a given with monotubes, 20" wheels, and aggressive tires.  At speed, the dampers turned those crazy earth shattering/dash destroying bumps on Chicago expressways into muffled bumps on the road.  Also the dampers recover quickly.  Driving into parking lots or steep driveways, my truck you to rock back and forth, now the truck rocks and correct quickly. No over correction.  I would highly recommended this kit as an alternative to the Bilstein kit.  If your looking to lift your truck, its hard to beat this package.
      Overall very happy with the kit and how it turned out.  Excited to get some off road time this hunting season!  I filmed the install and will be posting the video when its edited.
      Thanks!
      WF41
    • By ArnottInc
      Features:
      •    Made in the USA
    No registered users viewing this page.
    Jamie Palmer
    Jamie Palmer
  • Who's Online   98 Members, 0 Anonymous, 2,052 Guests (See full list)
