45mph wheel trys to pull out of my hand
i have a 2016 gmc savan ext wheel base cargo van . at 45 mph it starts shaking the front end on passenger side and jerking the steering wheel really bad and the dealship cant find a issue or firestone were i boughtthe tires . has any one figured this issue out yet ?
 Share
  • Similar Content
    • By hamz
      I recently bought a Sierra 1500 Denali because I love this truck but I am now noticing parts are really hard to find, I want to replace or delete my quad steer but have no idea where to start or look. I haven't been able to find anything in hours. Any help?
    • By The Pig Dusters
      Okay guys I bought this truck from a dealership in September. It was used and I got a 30 Day warranty. After the 30 day period, this is what’s happening. I got in my truck and noticed a rough idle. My truck would shake and out of no where the check engine light starts flashing and my traction control light comes on. I took it to my buddies and we got a P0308 Misfire Detected Cylinder 8. So I did some research.. I also had a code which was P219B. Air/fuel mixture ratio.
      I changed the spark plugs.. didn’t work. I moved coil packs.. the misfire didn’t move. So we watched Live data on the scanner and injector 7 was acting up. So we replaced all the injectors on that side and this truck is still missing.. I’ve ran seafoam through it and cleaned the throttle body and MAS.  My buddy things I have a valve issue or something wrong with the cylinder…
      there is no AFM deleted or anything of that sort. The truck has worked flawlessly until now. 135,000 miles on it. The rocker arms all
      looked great.
      please someone give me something to try. I just want my truck fixed lol.
      posting a link below of what it’s doing…
    • By chevelleusaf
      TIA for your help and time…
      BLUF: Ticking noise under truck, not heard from top of engine compartment.
      I noticed a ticking/clicking/pinging noise under my truck today, took a video, hopefully you can hear it.  Anyone else?
      Truck was in Park and Neutral (Parking brake engaged) and still heard the sounds.
    • By Nate_110
      Hey everyone. I have a 2016 Sierra Denali. A while back I opted to do away with the magnaride struts and installed BIlstein 6112s in the front with Cognito UCAs and BIlstein 5100s in the rear, also added Xineering bypass kit to clear the Magnaride errors. I had an issue recently with the stop mount on the drivers side strut blowing out. I contacted BIlstein about it and the rep told me he thought he had been told that the distance between the LCA and where the strut mounts into the truck frame at the top on a magnaride equipped Denali is shorter than a normal Sierra and that it was possible that the strut was too compressed, causing it to push through the top mount. Has anyone ever heard this or experienced this issue? I can’t find anything mentioned about it anywhere. I’m taking the truck in next week to get it fixed but if it’s going to just happen again I am wondering if I need to get different struts all together.
    • By Gabe Polo
      Hello I'm having a problem with these headlight that I installed on my 2015 GMC Sierra. I install the newer Denali headlight the blinker light stay on and when I turn on the driver side blinker it flashes the high beams and stuff. I need some advice the harness I use was from GEN5
    242.1k
    1.4m
    Mongo151
    Mongo151
  • Who's Online   5 Members, 0 Anonymous, 320 Guests (See full list)
