GMC-AT Posted October 28, 2018 Share Posted October 28, 2018 2000 Silverado - 5.3 (stock) I have a low speed whining noise coming from underneath. I jacked up the truck today and spun each tire, it's coming from the back tires only. When I spin either back tire the noise sounds like it's coming from the transmission or transfer case area. I thought it was the brakes when I first started hearing it. But once I jacked it up...it appears brakes are not making the noise. Noise goes away after 25mph or so.... Any ideas? See video below. Sent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMC-AT Posted October 28, 2018 Author Share Posted October 28, 2018 any ideas? Quote Link to comment Share on other sites More sharing options...
carkhz316 Posted October 28, 2018 Share Posted October 28, 2018 Is the driveshaft turning at all during this or is the opposite wheel spinning in the other direction? Quote Link to comment Share on other sites More sharing options...
GMC-AT Posted October 29, 2018 Author Share Posted October 29, 2018 Drive shaft spins...I noticed that. I only had the one rear tire jacked up...don't know if other tire would spin..Sent from my SM-G930V using Tapatalk Quote Link to comment Share on other sites More sharing options...
rjgti Posted October 31, 2018 Share Posted October 31, 2018 my first guess would be a u-joint Quote Link to comment Share on other sites More sharing options...
GMC-AT Posted October 31, 2018 Author Share Posted October 31, 2018 Yes, I was thinking that could also be the case. But all U Joints were just replaced about 6 months ago. Defiantly not the back U Joint Quote Link to comment Share on other sites More sharing options...
GMC-AT Posted November 9, 2018 Author Share Posted November 9, 2018 just an update - for fun I sprayed some PB blaster on the u joints and the slip yoke. The noise has stopped. I'm thinking the noise was coming from the front of the driveline... so the issue has to be the slip yoke making that screeching sound. Make sense once I think about it more because I had the slip yoke replaced not long ago with a new one to reduce the drive link "clunk" these trucks are famous for. It did help the clunk.. but it seems this noise may have started not long after that. Quote Link to comment Share on other sites More sharing options...
rjgti Posted November 13, 2018 Share Posted November 13, 2018 grease the splines in the yoke Quote Link to comment Share on other sites More sharing options...
