Air is only blowing out of vents
Disconnect the negative battery terminal for 5 minutes to do a reset.. If you have the right scan tool you can recalibrate it.
Sent from my SM-G965U using Tapatalk
After replacing the battery the system will attempt to re-calibrate itself.
https://www.gm-trucks.com/forums/topic/150420-air-door-stuck-on-hot/?do=findComment&comment=1318661
Quote
You might try the HVAC recalibration procedure:
Remove the HVAC/ECAS fuse for a minimum of 10 seconds. (Or disconnect battery)
Re-install the HVAC/ECAS fuse
Turn key on, but do not start. Make no adjustments to HVAC controls at this time. System will will move actuators as part of the re-cal. So hands off
Wait 40 seconds to 1 minute or so for the HVAC control module and actuators to re-calibrate.
I've always had the best luck at this point by turning key off. Removing key and closing the door. (Signals the BCM of a completed driving cycle)
