The slightest miss or hicc-up
changed the wires , plugs , and did a super duty injector cleaner
to no avail
there is no loss in power or worsening of it
and you can only tell at idle with or without a/c on
i can pop the hood and watch that bolt at the top of the throttle body
it'll move about 1/8" either way
but now with my magnaflow installed you can pick it up at the exhaust
just sounds like a slight miss or a burst of extra fuel into one or more of the cylinders
anyone else had this problem
did'nt know if it may be a sensor problem(AIC,TPS,ETC.)
any advice much appreciated
Todd :):sigh:
Is this something that just happened or has been going on for some time. In another forum we were talking about the 03's having a weird idle, with a slight vibration felt every 15 or more seconds...kind of like a sub thumpin'. They thought it might have to be with the timing, but someone else pulled up a tsb for wrong sparkplugs installed in some trucks causing this.
chev tech
i'll pass on the stealer AGAIN
got a brand new intake mani complete with all sensors
fuel rails and injectors for 125.00 on ebay(brand new)
a nice service tech said this was a problem on over 100k
(intake leak)
i sure am glad i have one friend that works for gm
and he admits he works for the STEALERSHIP
but thanks for your input
Keep on shotgunnin' parts, you'll get it! Eventially, one of those parts will fix it. Too bad you've had alot of bad dealer experience, there are alot of great technicians out there in the field. I've done tons of factory training and take my job seriously, and it just ticks me off sometimes on this forum to hear all the bad mouthing of "stealerships". Everyone is out to make a livin, and hey, sometimes we make educated guesses on a fix. But i know alot of great techs are on this forum and give some good advice, to help out people like you, thats all. Good luck on your truck.:confused:
