Shakeydeal Posted March 8, 2019 Posted March 8, 2019 I have a Zone 6.5" lift with what I assume are the stock Z71 shocks. I want to replace these for a little better ride. I am looking at the Bilstein 5100s front and rear. The part numbers they gave me are: 24-238304 (front) 24-186636 (rear) Does that sound right? Or did you get different part numbers? Any input on ride quality or comparison to anything else of similar value is appreciated. Shakey
khaledsamy36 Posted March 9, 2019 Posted March 9, 2019 These part numbers are not correct , they don’t match you lift kit hight - you need to get ones which supports 6.5 lift kit Sent from my iPhone using Tapatalk
Shakeydeal Posted March 9, 2019 Author Posted March 9, 2019 Well I talked to the guy in tech support at Bilstein yesterday and described the lift. He said if I have spacers under the front struts, which I believe this to be true, those are the parts I need.
jimmyboy8301 Posted March 9, 2019 Posted March 9, 2019 7 hours ago, khaledsamy36 said: These part numbers are not correct , they don’t match you lift kit hight - you need to get ones which supports 6.5 lift kit Sent from my iPhone using Tapatalk you're incorrect. the bilstein 24238304 are 0-1.85" shocks. so if he keeps them at the stock height WITH the 6.5" spacer it will work perfectly.
jimmyboy8301 Posted March 9, 2019 Posted March 9, 2019 20 hours ago, Shakeydeal said: I have a Zone 6.5" lift with what I assume are the stock Z71 shocks. I want to replace these for a little better ride. I am looking at the Bilstein 5100s front and rear. The part numbers they gave me are: 24-238304 (front) 24-186636 (rear) Does that sound right? Or did you get different part numbers? Any input on ride quality or comparison to anything else of similar value is appreciated. Shakey i'm not sure about the rears, but the front shocks are correct. leave them set at 0" (stock height) and they'll work flawlessly and give you a more controlled ride.
