01 Silverado fuel line replacement
Jeffhaynes
I'm in process in changing fuel lines. They are 2 peice and part the lines that run up to motor are not set right I dont think because they are almost touching front driveshaft. I read there is line connector on top of bell housing but it's not connected when took old lines off so have nothing to go off of
Bend them slightly if you have to, and fasten them wherever you can.
About how far away should they be from drive shaft and should it be on towards outside of truck or inside a linkage of I what i think is for 4wd
I'd say 1/4" clearance should be enough. Of course, the more the merrier. I can't tell you as far as routing goes - been a while since I've done one. You'll have to use your own judgement there. Think about how the engine and the rest of the driveline will torque under load - as long as the lines don't rub against any metal, or get put under stress in any way, they'll be fine.
