Sign in to follow this
Charley@208
Looking for center console cup holder
Quote
Hi everyone,
I’m looking for a cup holder for a center floor console for a  2016/2017 Silverado/GMC 1500. The part # is 23495230 / cup holder, upper trim “burnish”. All the part sites I visit say it’s a discontinued part. I haven’t been able to locate one on eBay either. If anyone can give me a lead I’d appreciate it. Thanks in advance.
Share this post
Link to post
On 4/12/2019 at 3:46 PM, [email protected] said:
Hi everyone,
Thanks, I’ve found a newer part number that is the same part. Gm # 23467147 if that helps anyone else.
Share this post
Link to post
The trick is:
you can purchase the older, 2014 / 2015 cup holder in any finish you’d like. Remove / separate the outside lower cover from the top trim and liner then pop it in place into a 2016 / 2017  center console upper trim. You can separate the top trim from the lower cover by inserting a plastic trim tool into the seam at the end of the lower cover near the ball detents and separate tithe top from the bottom. GM designed the newer upper trims to use the same cup holder trim pieces without the lower cover.
The new cup holders are only available in axiom and carbon black.
Share this post
Link to post
