tyler.frost92
New limitation found with Stabilitrak
Found out you cant shut stabilitrak off if any of your tires read 10psi or lower.
Share this post
Link to post
Damn I don’t have sensors, that explains a lot !
Share this post
Link to post
On 6/19/2019 at 1:28 AM, Mileguru said:
I wish someone would guinea pig this:
http://www.tuningbyshanehinds.com/2014-12-gm-truck-stabilitrak-disabler
Turns off Stabilitrak with the flick of a switch.
Ive seen plenty of people have good luck with those on a facebook group for these trucks. Ive thought about getting one.
Share this post
Link to post
Ended up making my own bypass switch. Works great. If anyone is interested in part numbers for connectors let me know
Sent from my iPad using Tapatalk Pro
Share this post
Link to post
Post it up!
Share this post
Link to post
Post it up!
Basically these two pigtails plug in inline with one of your front wheel speed sensors. Driver's side makes the most sense because it's the closest route into the cab. Wire together the corresponding wires on one side of the inline "harness". Extend both of the others inside your cab to a rocker or toggle switch. So basically all you're doing is interrupting the signal on one wire. This will kill abs, traction control, trailer brakes, and stabilitrak. As soon as you flip the switch again everything goes back to normal. No check engine lights or warnings. It took tons of research and cross referencing to find the correct connectors/pigtails. I'd suggest soldering and heat shrinking your connections. The best part is it can be removed easily as all the wired connections are made inline between your two stock connections that don't have to be modified.
Share this post
Link to post
How I decided to mount the switch.
Share this post
Link to post
Thanks! I added these to my amazon cart for later. I'll be asking you questions in the NEAR future 😃 I'm going to look up how to unplug the wheel speed sensor and figure out the order in which these plugs should go. Is a wheel speed sensor the same thing as an ABS sensor (harness wise)?
FYI, for you all with a 5.3L and 4WD, you might want to read this https://www.carcomplaints.com/news/2019/gm-wheel-speed-sensor-recall-braking.shtml first as it looks like unplugging a wheel sensor messes with braking.
Share this post
Link to post
Thanks! I added these to my amazon cart for later. I'll be asking you questions in the NEAR future  I'm going to look up how to unplug the wheel speed sensor and figure out the order in which these plugs should go. Is a wheel speed sensor the same thing as an ABS sensor (harness wise)?
The wheel speed sensor and abs sensor basically refer to the same thing. It's a simple plug connection with an annoying red "lock". You just have to pry it backwards before the clip releases. The sensor goes from the hub to the wiring harness at the top of the wheel well. You can't mess up where the plugs go. They're just male/female versions of eachother.
Share this post
Link to post
i'll be following this thread
Share this post
Link to post
So is "unplugging the wheel speed sensor" just like as shown in this video? 6:30 mark.
He's replacing an ABS sensor in this video. So for sure the ABS sensor wire is the same thing as the wheel speed sensor?
https://www.youtube.com/watch?v=eWeDXb7HF74
Can you re-explain how you connected the two small black pigtails and one large red pigtail again? What's the order of connection with those and the two open ends of the wheel speed sensor and what wires then connect to a toggle switch?
Nice placement of the toggle switch, by the way. Did you follow the steps used in the Shane Hinds product (http://www.tuningbyshanehinds.com/2014-12-gm-truck-stabilitrak-disabler), or did you find an easier way?
Share this post
Link to post
I followed no instructions, just understood what others were doing with their 50+ dollar switches and made my own. Might not be as nice but it's functions properly, and gave me something to do. Not sure if I can make it more simplified than this lol. It's almost plug and play 5d30109b257f9f7cfdd4abfc724476c4.png
Not drawn to scale or very well for that matter. Used my finger lmao
Share this post
Link to post
I wouldn't spend $50 either for something that can be made this easily. They are actually charging $90 for this now (it used to be $70 or $80 if I recall). Great job on piecing this together!!!
I totally get your drawing now. Thank you for that! I was getting lost because I though I had to use BOTH of the small black pigtails.
Great post. I hope a lot of people see this and benefit from it because there used to be a lot of questions about how to fully disable Stabilitrak.
Share this post
Link to post
Ah. Yeah, those horn adapters just come in a pack of two lol.
Share this post
Link to post
