Hey guys just wanted to share tis bit of info that I was able to find. It was difficult locating a driveshaft for a 14+ GM 1500 so I hope this helps.
After spending tons of time trying to find a less complicated way to upgrade my DS I visited alldrivelines.com (referral from a member) and saw the 800hp rated 2 piece shaft. I called to verify compatibility and was let down by the rep. It is not user friendly for the 4x4's.
However, after asking me some great questions Shelby @ Alldrivelines  (661) 633-2303 simply said why don't you get our 1,200hp rated driveshaft for the 14+ GM 1500.. I said ..."wait huh". Tell me more. This is currently not listed on the website.
It is a 5" 6061 Aluminum shaft with a .125 wall thickness. It is rated for over 1,200 HP and 7,300 ft tq. She can get the correct size for other models too (bespoke).
I'm running the following with a Stock Trans/Transfer Case and ride hight.
  • Make: GMC
  • Model: Sierra 1500 Denali
  • Drive: AWD/4WD
  • Loc: Rear
  • Bed: 5'9"
  • Chassis: 143.5"WB
  • Doors: 4 Door
After some negotiating it ended up being $580 SHIPPED from CA to MA!!!.  (She also suggested the upgraded billet slip yoke rated 1200hp it was an extra $100 so I'm actually $680.00 shipped)**
Just a heads up folks. If you want a Driveshaft that can handle high speeds, high HP and TQ this is the place to go. Call Alldriveline (661) 633-2303 and ask for Shelby. Mention my last name Melaas and they'll cut you the same deal.
A 1,200 hp rated shaft with the billet yolk for $680 shipped. I don't get anything for it I just asked if I could refer my friends here for the same deal and she said sure. Very nice Lady.
Lastly it is a 2-3 day processing and shipping for me (ca - ma) is about 3-4 days. I should have it next Thursday! I will send pics.
PM if you have any questions.
Edited by DenaliX14
  • Like 3
Take some pics after your install if you dont mind. I am really interested in doing this as well. I have a slight shake 75-80 that it would be worth trying to see if it fixes. You plan on installing yourself? Any downside to a two piece versus one piece?
Will do, it's current expected delivery is Tuesday 27th. I'll end up installing on my own. I'll snap some photos as soon as I get it.
I believe a two piece creates a weak point at the middle joint. Sure you can get an upgraded one however, a one piece this thick is always going to be stronger.
7 hours ago, Chad2815 said:
Ahh ok, I thought you were going with the 2 piece version on their website.
Nope. It doesn’t support the power I’m aiming for. Also, it doesn’t work for 4X4 trucks.
That is a pretty girthy shaft you have there...
Did they tell you what the max RPM of the driveshaft is? You can kill a 1200hp rated driveshaft with 200hp if you can spin it past its tolerance.
You running your truck at the Brickyard or Daytona?  I reckon a shaft set up like that is good for about 8,100 rpms or so, guessing the tube length is about 67 inches?
 I’m not doing anything with the truck for the near  future  anymore. It just broke on the Dyno
Edited by DenaliX14
